Old 11-22-2015, 07:53 PM   #1
DavidMPDK's Avatar
Fr3 stat list
I don't know of a category to place this so I will post new.
My memory is not what it use to be. It seems anymore for new info to be remembered I have to purge out some old. (Hard drive is full) Questions always seem to rise from fellow RV'ers about my FR3 Stats. So for my own piece of mind and (info availability for the DW) to answer these questions, I made a quick reference card that we put on the visor. I've had people say this was a good idea. So, I post it to you just in case you haven't gotten to it yet.
2016.5 FR3 30DS AKA "Serenity"
Searching for that perfect spot with loving Wife & 2 mini dachshunds
DavidMPDK is offline   Reply With Quote
Old 11-23-2015, 03:20 AM   #2
Just a correction on your stats because FR3's website is incorrect on the Front GAWR. It should be 7,000 lbs instead of 8,000 lbs. Our 30DS has it on the Ford placard next to the drivers seat too. But no worries, you'll be fine on your front axle, just the rear you'll most likely be overloaded. Anyways, good cheat sheet for the coach to have on hand!
https://www.fleet.ford.com/truckbbas...9_SB_specs.pdf
KansasFR3 is offline   Reply With Quote
Old 11-23-2015, 05:11 AM   #3
Witch Doctor's Avatar
That's good to have on hand, not a bad idea....
Coachmen M/H
Concord
2018 / 300 DSC
