Old 05-21-2017, 07:00 PM   #1
2020 Bershire 34QS
FR3 water tank drain tube cap
The plug/cap for my 2016 FR30DS fresh water tank drain tube has gone missing. I have attempted to cap it with a PVC 1/2" cap. It fits, but no matter what I do to seal it (o ring or gasket), I still get a drip. Can someone check their drain tube and tell me what plugs the end?
Thanks,
Bill
PS: Hope to see you all at Goshen in August.
MrBill16 is offline   Reply With Quote
Old 05-21-2017, 07:14 PM   #2
Ditch the cap
Hi Bill, Ditch the cap, which seems to already taken care of itself. I just modifed my 2018 304BS by removing the cap and replacing it with a 1/4 turn, threaded 1/2" PVC valve. Drains fast, and no cap to lose.
TheWolfPaq82 is offline   Reply With Quote
Old 05-21-2017, 07:28 PM   #3
2020 Bershire 34QS
Makes sense, but I'll probably wind up with the same leak. Does the PVC valve have a gasket?
Old 05-21-2017, 07:29 PM   #4
pvc valves for each. no leaks, no hassle.
Combatcoal is offline   Reply With Quote
Old 05-21-2017, 07:48 PM   #5
My 2014 is a 3/4 size.
jbutch is offline   Reply With Quote
Old 05-21-2017, 07:52 PM   #6
Teflon tape on tread, no leaks. my factory cap was leaking and I just picked her up last wednesday. You won't regret the valve.
Old 05-21-2017, 07:55 PM   #7
Could be either, pic looked like 1/2, but yeah, 3/4 also. I found both valves at local hardware store.
Old 05-21-2017, 08:05 PM   #8
2020 Bershire 34QS
Thanks for all the replies. I do have a 1/2 cap on now and it fits. I added an o ring over the threads and a washer in the cap and I still have a drip every several minutes. I'll add the Teflon tape next. BTW, it was the dealer that winterized my unit last season. I discovered the cap missing when de-winterizing this year.
Thanks to all.
Bill
Old 05-21-2017, 08:15 PM   #9
Check out a 1/2" PVC valve if you get a chance. Sure beats having to worry about the cap. Have a good one !
Old 05-22-2017, 06:40 PM   #10
Screen off the drain
I made a "cover" for the drain with a dome of window screen. It will keep out road debris and mud daubers that can plug them up
Enconcapt is offline   Reply With Quote
Old 05-22-2017, 07:19 PM   #11
Thanks to all.
Bill
If the dealer did it, he should replace it. I believe it is a PEX type fitting so you should be able to get them in the hardware store in the PEX plumbing section. Just bring in the cap you have left to match it.
ProfChuck is offline   Reply With Quote
Old 05-22-2017, 07:58 PM   #12
woodyrock1's Avatar
ID:	138763 this will work.
05 Ram 3500 Cummins Dually
14 8280WS Rockwood Sig. Ultra Lite
Prodigy 3 brake Controller
TST 507 TPMS
2017 = 30 nights /
2018 = 7 nights
woodyrock1 is offline   Reply With Quote
Old 05-23-2017, 05:37 AM   #13
Screen cover
I added a 1/2" x 3/8" barbed fitting to the bottom of my valve and have a blk vinyl cap that goes over the end of the barbed end of the fitting. Did a similar mod on my old Jayco Jayfeather...9 years and never lost a cap.
Old 05-23-2017, 05:40 AM   #14
That's exactly what I modified mine to. Added a 1/2" threaded x 3/8" barbed fitting to end and cap it with a blk vinyl cap to keep debris out of it. Drains fast and doesn't degrade like factory valves.
Old 05-23-2017, 09:25 AM   #15
2020 Bershire 34QS
I agree, but they're 35 miles and 2 tolls down the road. It's not worth the cost to go back and I planned never to go back based upon some other issues.
2020 34QS
2016 Fusion Hybrid TOAD
Old 05-23-2017, 12:52 PM   #16
Wolverine 1945's Avatar
Our drain has no cap,,, and has never leaked a drop ???
Maybe the drain valve is not sealing ???
Wolverine 1945 is offline   Reply With Quote
Old 06-06-2017, 08:19 PM   #17
Originally Posted by woodyrock1 View Post
Attachment 138763 this will work.
Yes that looks really good.
Old 06-06-2017, 08:23 PM   #18
yep got two of them, they are awesome
Old 06-06-2017, 08:39 PM   #19
Here's the setup I made Click image for larger version
Old 06-06-2017, 11:26 PM   #20
+1 on these as drain valves. I even cut slots in a piece of PVC pipe so I can open/close mine without getting on the ground to reach it.
madmaxmutt is offline   Reply With Quote
drain, tank, water, water tank
