Old 10-10-2014, 07:28 AM   #1
Fresh water drain
Hi everyone, just picked up my new FR3 30 DS.. How do I drain the fresh water? I'm used to a class C and turning a spigot. Under the water tank I see an overflow drain, a low point drain and I assume the fresh water drain..Click image for larger version
Name:	ImageUploadedByForest River Forums1412944080.440125.jpg
ID:	64455. Which cap is the fresh water drain, black or white.
TheresiaC is offline   Reply With Quote
Old 10-10-2014, 09:14 AM   #2
The middle hose, black cap, should be the fresh water tank, while the end, white cap should be the water pump drain. This is what I was shown by the dealer, and it was that way when I drained my tanks this year.
RiverRat22 is offline   Reply With Quote
Old 10-10-2014, 01:00 PM   #3
Great, thanks!
Old 10-10-2014, 02:46 PM   #4
Online_17's Avatar
Hmmm, I always drain the blue hose with the white cap....?...
Online_17 is offline   Reply With Quote
Old 10-10-2014, 04:19 PM   #5
Never noticed the color of hose until this picture, but the dealer told me middle hose fresh water, end hose pump. But.... I could be mistaken on color.
Old 10-10-2014, 05:18 PM   #6
Fresh water drain
I have two blue hoses. Took the cover off the side access and traced the tank drain.. Added the plastic valves which is better than removing the plug and getting wet. The one with the nipple is where I side a hose on and then let water drain out.Click image for larger version
Name:	ImageUploadedByForest River Forums1412979496.245227.jpg
ID:	64512. The other is the low point drain
b1barnes is offline   Reply With Quote
drain, fresh water, water
