Old 09-26-2015, 01:57 PM   #11
leisurelarry's Avatar
Hook up a hose from a spigot to the black water tank flush. Hook up your sewer hose, of course you'll need to be at dump site. Open the valve to your black water tank and turn on the spigot. I use a clear 45 between the coach and the sewer hose to keep track of the action. Rinse until clear, simple as that! I also use a separate hose just for the black water tank flush.
leisurelarry is offline   Reply With Quote
Old 09-26-2015, 03:05 PM   #12
So leisurelarry, when we dump at a campground we cannot use the black water flush because there is no way to hook a hose to a spigot to get water. Am I thinking we need to do this at home?
imcruzn
imcruzn is offline   Reply With Quote
Old 09-26-2015, 03:46 PM   #13
keith52's Avatar
Most, but not all, dump stations have a water spigot for cleaning up any sewer spillage. Just hook your hose up to the spigot and let it run a few minutes. Make sure the tank valve is in the open position. Best to use the flusher before things dry up in the tank.
keith52 is offline   Reply With Quote
Old 09-26-2015, 03:58 PM   #14
Yes imcruzn, there are some dump sites that do not have a hose to attach to your black water flush, only a hose to clean up the drain area. I usually am in a full hook up site where I can use a hose splitter and hook up a hose for my fresh water and a hose for my black water flush. Other wise, yes I flush at home. I am blessed and have a dump site where I live.
Old 09-26-2015, 07:14 PM   #15
fpo1123's Avatar
Leisurelarry. Were did you get the black water flush, and how easy is to hook up? Sounds like something I could really use.. thanks.
MSG (Ret)
U.S. Army
Active-duty 66-92
2015 FR3 30DS
fpo1123 is offline   Reply With Quote
Old 09-26-2015, 07:32 PM   #16
Blackhat6mike's Avatar
Originally Posted by Brother Les View Post
You have some type of debris in the check valve area of your fresh water pump. Speck of calcium or something like that. May have take the pump apart a little and clean it up. Not too hard to do,
Three times I've had to open the pump and clear all the faucets and even the input to the head because jiblets of plastic that were left in the fresh water tank when the factory installed the level sensors, input spout an pickup spout. Not sure I will ever get it all out. Each time I add fresh water, it stirs up a new batch. Wish it were calcium, I can disolve that with ease. Plastic, not so easy.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 09-26-2015, 08:25 PM   #17
fpo1123, it was very simple to install. You need a hole saw to cut the hole in the side of the tank and some silicone sealant to make sure it's watertight. The directions are in the package. You can get them at any camping world and most RV supply stores. I got mine on Amazon.Click image for larger version
Name:	ImageUploadedByForest River Forums1443317099.345498.jpg
Old 09-26-2015, 09:11 PM   #18
Lexi2007's Avatar
That Happened To Us,,,In The Desert
The very same thing happened to us. I called Forest River and spoke to a warranty person. He said there could be two issues, one, they did not install the plumbing correctly and two, there could be the issue with the valve. We have an appointment to take the rig into a Forest River dealer to sort things out. One thing we haven't been able to locate is the pesky valve. Can anyone help?
Also, our 2015 did not come with a black tank flush inlet. We purchased a clear attachment that affixes to the main sewer pipe on the rig and it has a connection for a hose and a valve to allow the water to be turned off and on. We've used that several times but I'm not sure just how clean it gets. While at Camping World today, they have several flexible wands that can be passed into the black water tank through the commode with a water hose affixed to it. Some of the pricier ones have rotating heads and make sense to me. We may just get one of those as we already have the dreaded control-panel-indicates-tank-2/3 full-when-we-just-finished-emptying-it.
Ken & Val [Lexi's mom] Moczygemba & Tori the dog
Adkins, TX
2017 Coachmen Concord 300 DS [Lexi III]
Lexi2007 is offline   Reply With Quote
Old 09-26-2015, 10:05 PM   #19
PhotoMaster's Avatar
I posted pictures from when I installed my black tank flush. I'll find them and post them. The installation was easy and the flush is priceless!
Greg, Barbara and Cody the wonder-pup.
2014 FR3 30DS
(and 2 200cc Scooters)
PhotoMaster is offline   Reply With Quote
fresh water, tank, water, water tank
