Old 10-06-2015, 04:07 PM   #11
Originally Posted by Fusionak View Post
Hi, just got a 2016 Grey Wolf. I noticed a leak/drip coming from underneath the fresh water tank. I'm not sure if the solution is to "crimp the connector" or if I have to do something else. It's not too easy for me to get underneath the trailer so I will get a friend to do so for me.
I took a picture and caught a drip as it was about to fall from the left nipple. There are 2 nipples beside each other, can someone tell me what they are use for? The overflow rubber hose is at the far right.
Thank you.
Since I just bought it I took it back to the deal to let them figure it out. Turns out my whole water take was installed incorrectly from the factory causing excess pressure to build up in the take. It also not mounted at the correct angle contributing to the leak. All fixed now.
The Camping Mesekes
2016 Forest River Salem Cruise Lite 180BH
mmeseke is offline   Reply With Quote
Old 10-07-2015, 01:40 PM   #12
Canadian eh'
Holy cow... I didn't think it could be that big of an issue. Guess I should take it in to make sure. Thanks
Fusionak is offline   Reply With Quote
Old 10-07-2015, 01:41 PM   #13
Canadian eh'
Originally Posted by VinceU View Post
Looks like a low point piping drain. Any chance there is a drain valve open or cracked?
I'll first check for cracks or loose connection before taking it in
Old 10-07-2015, 09:17 PM   #14
Did you try to just tighten the threaded part on the end of the low point drain? That is a common issue that is easily fixed.
jrwalkerpa1 is offline   Reply With Quote
Old 10-08-2015, 09:26 AM   #15
Canadian eh'
Yes I did. I tightened it by hand as I was told if I use a tool I could break it. Just to point out though, this is underneath my fresh water tank. I have separate low point drains (red and blue) near my hot water tank.
I'll be getting underneath it this weekend to get a better look. I'll update this thread on results.
Thanks.
fresh water, leak, tank, water, water tank
