Old 07-02-2018, 08:45 PM   #1
Fridge not working
2016 30DS fridge not working. Freezer works, fridge light works. Connected to shore power and leveled. Just got it back from shop for a couple checks and one of the things they did was replace fridge light. Supposed to leave Wednesday for a quick trip 🙁 Fridge worked before we took it in ...
KevandSyl is offline   Reply With Quote
Old 07-02-2018, 08:48 PM   #2
What refer?
If freezer is cold then everything works.
donniedu is offline   Reply With Quote
Old 07-03-2018, 07:56 AM   #3
ceedog's Avatar
As stated above, if the freezer works, everything else works. RV refrigerators take a long time to cool down due to their not having a fan to circulate the air. You can purchase a portable fan from CW or Amazon for around 10 bucks.
It ain't easy being me...I've tried.
ceedog is offline   Reply With Quote
Old 07-09-2018, 11:30 AM   #4
HortMi's Avatar
I posted this in another section. After four months I finally found out how to adjust the temp in my fridge. If you freezer is freezing everything is working correctly as posted above .
HortMi is offline   Reply With Quote
Old 07-09-2018, 11:36 AM   #5
HortMi's Avatar
ID:	178820Here is my adjustment.
2017 FR3 28DS Sorry it's sideways.
Old 07-09-2018, 04:32 PM   #6
rk06382's Avatar
The one thing that was not covered is the plastic slide that holds the thermistor.
Mine was loose enough that when I slide it up the fin, the thermistor slide down the sleeve. Moving the slide did nothing to the thermistor.
I had to drill a small hole in the slide. Then I used a tie-wrap to clamp the thermistor in the slide.
Now when I moved the slide up the fridge got down to 34F.
Robert
2018 FR3 28DS
Samlex EVO-3012 Inverter/Charger| 400ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | Dometic 320 | SnapPads |
Solar Power & Battle Born batteries thread
rk06382 is offline   Reply With Quote
fridge
