Old 08-19-2016, 01:52 PM   #11
Head Rambler
Originally Posted by DutchRv View Post
Would that be top or bottom in the picture?
As Herk said, it's the top item in the pic. It plugs into the control board. Just turn off the power or unplug the power cord and unplug one of the wires going to the element and see what resistance you get across the leads.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-19-2016, 01:58 PM   #12
RetiredRVer
In your photo of the control panel, it looks as if the gas button is out....if it is, it will only run on propane, and there will be no lights illuminated. Just check to see if that is the case.....
Joe & Sandy
Mentor, Ohio
2015 Chevy 2500HD Crew Cab 4X4 6.0 "Gasser"
2014 Wildwood Heritage Glen 282RK TT
2018 "FROG!" To Alaska
checkmate99 is offline   Reply With Quote
Old 08-19-2016, 01:58 PM   #13
Herk7769's Avatar
We worked a similar issue in the other thread.
Help with running refrigerator off propane!
Sorry I confused the two ...
HAM CALLSIGN - KC3FFW
Old 08-19-2016, 02:03 PM   #14
Herk7769's Avatar
This is most likely the issue. If you press the "gas button" back in, the auto light should come on and the AC heater in the fridge will start working if everything else is OK.
Old 12-21-2016, 01:30 PM   #15
I am having the same issue with my fridge. It is the same model, 2016 build date. It works on propane but not on electric. The outlet is working and the board recognises the incoming power, if in auto and I unplug it, it kicks in the LP.
Everyone was completely preoccupied about the bottons in their answers but I don't see the fix or if the OP got it working on AC.
I have not been able to test the coil, need batteries for my multimeter.
RESET is offline   Reply With Quote
Old 12-21-2016, 06:15 PM   #16
Herk7769's Avatar
There is an AC fuse on the control board and of course there is an AC heater in the stack; either or both could be bad and give you this failure mode.
While you may not have this model, evaporative refrigerators are all pretty similar.
ID:	126901   Click image for larger version
Name:	Camper Fridge 008.jpg
ID:	126902   Click image for larger version
Name:	Circuit diagram.jpg
Old 12-21-2016, 06:46 PM   #17
Plan on testing the fuse and coil as soon as I get home. The fuse looks good but I had to get batteries for my multimeter to be able to test anything. I will post my findings in the morning.
Old 12-21-2016, 07:07 PM   #18
Also check the stack overheat reset.
Name:	Refrigerator Overheat sensor.JPG
Old 12-21-2016, 07:28 PM   #19
Do I just check that for continuity?
Old 12-21-2016, 10:01 PM   #20
Looking at your pic, it looks like the black dot in the center is not sticking out as far as mine. Is this a reset button? Also, I thought that sensor was only for gas operation, since it is lower in the chimney than the electric element.
Small note, was too dark when I got home. Will have to do the tests in the morning. Fridge is running on LP just fine for now.
fridge
