Old 08-19-2016, 12:20 PM   #1
Fridge won't work on 120VAC
2015 28DS
Dometic DM2652RBX
Won't work on 120VAC. I measured the outlet, it works. On circuit board both fuses are intact. Breakers fine. Get's cold on LP just fine.
On fridge itself it's on auto (prefers 120VAC, when no 120VAC, LP kicks in)
Any ideas folks?
PS, brand new.
ID:	117771   Click image for larger version
ID:	117772   Click image for larger version
ID:	117773   Click image for larger version
DutchRv is offline   Reply With Quote
Old 08-19-2016, 12:30 PM   #2
Head Rambler
Unplug one lead in the electric element and measure the resistance across the element. It should read about 44 ohms.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-19-2016, 12:59 PM   #3
rbq
If it's new then get it to a dealer & let them deal with it. Otherwise if you want to fix yourself another option is to disconnect the 2 leads that go to the heater rod, turn off the fridge and then plug those 2 leads into a power cord. You can see where the heater goes into the boiler part of the cooling system. That heating element should be hot (don't burn yourself). If the fridge is cooling on LP then it sounds like you have a burnt out heating element. Make sure the fridge is level.
2001 Chevy Silverado
2011 Rockwood Roo 233S
rbq is offline   Reply With Quote
Old 08-19-2016, 01:04 PM   #4
rbq
Your picture of the fridge control shows no lights. Did you have it set on gas only setting? Press the on switch & turn it to auto. If the lights don't come on then be sure & check the fuse in the converter box as well as the 2 or 3 in your panel on the back of the fridge.
Just went through this little exercise when my fridge wouldn't cool on AC or LP. Ended up being a leaky cooling system & had to replace fridge.
Old 08-19-2016, 01:04 PM   #5
Would that be top or bottom in the picture?
Old 08-19-2016, 01:12 PM   #6
Herk7769's Avatar
Top in that picture is the heating element; bottom is the propane stack overtemp sensor.
Check again your "gas only" switch is not on as suggested.
HAM CALLSIGN - KC3FFW
Old 08-19-2016, 01:18 PM   #7
No it is set to auto
Old 08-19-2016, 01:44 PM   #8
Herk7769's Avatar
If there are no lights on the panel, you need to check the fuse in the power panel.
However you say it gets cold on AC, so I assume you have good 12 volts.
I further assume the stack temp sensor is not open.
Next you need to check that there is 12 volts at the solenoid when the unit is calling for gas.
Try tapping on the top of the solenoid to see if it is hanging up due to possible corrosion inside.
Beyond that, you can check if you can smell propane when it is trying to light. Do you hear a snapping sound when its trying to light?
I have attached a troubleshooting guide that can go from there.
Name:	Camper Fridge 002.jpg
ID:	117785   Click image for larger version
Name:	Circuit diagram (2).jpg
File Type: pdf Fridge Operation and Trouble shooting.pdf (95.6 KB, 39 views)
Old 08-19-2016, 01:56 PM   #9
jftrombley's Avatar
You should have a GFCI protected outlet feeding the refer. If so reset it or replace.
jftrombley is offline   Reply With Quote
Old 08-19-2016, 01:59 PM   #10
Lou - Point of clarification, its the opposite, works on gas not on AC according to OP. but great info with the diagram and attachments.
foretm is offline   Reply With Quote
fridge
