Old 04-16-2019, 12:56 PM   #1
Front seat Replacement 2015 28DS
Hello,
Has anyone replaced the front seats on their rig? The stock seats are awful and my wife needs more support for her back. If you have replaced them, please let me know what you got.
Thank you!
Jon
JonnyVinSB is offline   Reply With Quote
Old 04-16-2019, 04:35 PM   #2
I just cut mine down and it made a big difference cut 2” off the height added a pipe and bolted it together. I also added 3/4” to the front only so you don’t feel like your falling off. 2 7/8 pipe I had to grind it down a bit to get a snug fit. Both seats took 3/4 of a day and $15.00
ID:	201914   Click image for larger version
ID:	201915   Click image for larger version
ID:	201916   Click image for larger version
ID:	201917   Click image for larger version
Iankerr is offline   Reply With Quote
Old 04-18-2019, 02:51 PM   #3
This is great! I will try this fix before thinking about changing them out.
Thank you for taking the time to help!!! Jon
Old 04-18-2019, 10:20 PM   #4
Your welcome
The pipe is 2 7/8 I had to grind it a little so it fit snug. 2” cut is good for a 5’10 or 6’ person if shorter I would go 2 1/2. The wood filler I used is 3/4 but I had a 1/2 in there to start. Is a easy figure when the seat is in place. Just turn it and add or subtract. Hope this helps
Ian
replacement
