Old 01-21-2019, 07:48 PM   #1
Frustrated with fr3
I swear I'm so angry at first river right now. U bought my fr3 in oct 18. Its a 19. The floor was scratch said they would fix it but Nov 1 I called and the still didnt have part. Started our trip. The trip fell off the slide second time it went out. It wasn't touching any thing. Third time the read slide went out the legs started bending. Now they are hanging by one nail. The toilet sensor says its 3/4 full even after dumping . The left camera stopped working. The back up camera is not focused straight back. The cabinet door has fallen off as it's only held on my 2screws. Tonight was going to use dinette as a bed and the table is too narrow it slides off rails as soon as any weight is put in it. And of course falling off the rails damaged the dinette area. I've called forest river corporate 3times to try to find where I can get service since I'm now far from home. Everytime I get voice mail and it says they will call within 42 ,hours. Havent heard back yet. I'm angry . Does anyone have a better way to contact them. I wish I had bought a different brand.
Lyndall is offline   Reply With Quote
Old 01-22-2019, 12:29 AM   #2
rk06382's Avatar
Have you called CoachNet? A year of CoachNet was included with your FR3.
They have 24/7 RV technical and roadside assistance. They will also help help you find a local Forest River dealer.
They were able to help me when I had a bedroom slide failure.
Robert
2018 FR3 28DS
Samlex EVO-3012 Inverter/Charger| 400ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | Dometic 320 | SnapPads |
Solar Power & Battle Born batteries thread
rk06382 is offline   Reply With Quote
Old 01-22-2019, 10:05 AM   #3
robo44's Avatar
I've had good luck with sending in the question via email. They have always contacted me withing 24 hours. And directly called me..
Forest River RV Contact Us - Forest River, Inc.
2019 FR3 33DS Motorhome
Travels California Coast & Beyond
robo44 is offline   Reply With Quote
Old 01-22-2019, 10:14 AM   #4
Mr. Dan's Avatar
Instead of attempting to contact Forest River, the parent company, I'd try to contact the FR3 division.
Service
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 55; booked = 20
Old 01-23-2019, 04:38 PM   #5
I contacted Nicholas Hoover and he was a GREAT HELP for us when we had trouble. I even had them pick it up and drive it to the factory for repairs. They had it for 4 weeks. I made a 10 page punch (single line spaced) list of items that needed repair.
My FR3 32DS is the worst manufactured coach I have ever owned. It is all fixed now (by me mostly) but I don't care for it because of all the problems we had. We are going to an RV show in town tonight to look at other coaches. We will look at new, but will probably end up with a 2-4 yr old Newmar or other quality BUILT COACH.
I know all coaches have some problems, but ours had way too many to mention. They numbered well over 100. Good thing I am handy and can fix most anything. In my opinion Forest River RV's rate about a 1 or 2 on a scale of 1-10.
Good luck with your repairs.
I find lots of Bourbon & Coke helps me when I work on my FR3.
Kentucky Bob is offline   Reply With Quote
Old 01-24-2019, 10:27 AM   #6
A lot of the stuff is fixable with no frustration the dinnet needs a filler the cabinet door the holes are stripped so add some glue to a small piece of wood insert it into the hole and install the screws. The black tank sensor has a piece of toilet paper covering it. 3/4 fill the tank with fresh water and go for a drive a windy one that will dislodge the paper. You will have to Waite on the floor
Iankerr is offline   Reply With Quote
Old 01-24-2019, 10:28 AM   #7
There has to be a fuse or a wire off for the left camera but the rear is adjustable
Old 01-24-2019, 10:46 AM   #8
The left camera wire is probably loose where it plugs into the multiplexer. The multiplexer is located behind the center panel on the dash which holds the monitor screen . It is a small metal box and the camera cables connect to it.
Bob
Old 01-29-2019, 12:42 PM   #9
My 32DS is at the dealer for a non-functioning left camera as we speak. FR overnighted me the part, the multiplexer under the dash is not very impressive... standard AV cables.
Griswards is offline   Reply With Quote
Old 01-29-2019, 01:00 PM   #10
I pushed in all the cables and got all the cameras to sho on the screen . I then fed the rear camera input into the new multiplexer and fed the output from the new multiplexer to a new camera monitor from amazon and mounted it on the dash to the left of the steering wheel. This gives me full time monitoring of the back end of the rv and my toad car. I did this because my system usually responded slow when switching from a side camera to the rear camera.
I ALWAYS want to know what is going on behind the rv and can always use the side mirrors if the side cameras start going nuts.
Still don't like my FR3 32DS I started looking for at Tiffen RV products now (3-4 yrs old)
fr3
