Old 12-24-2015, 07:16 AM   #21
Turbs is correct but at what point does it create a problem?
Before ethanol was common in gasoline, I put "Gas Line Antifreeze" in my tank to remove moisture. That stuff was nothing but alcohol. It absorbed water and then flowed to the carburetor and was burned.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
Old 12-24-2015, 07:17 AM   #22
TURBS's Avatar
Sea foam sea foam sea foam
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 12-24-2015, 07:20 AM   #23
How's this for an ideal solution?
Keep the tank full, then at least once per month go camping and use it all up. That avoids stale gas, moisture in the tank, and household chores.
RamblerGuy
2011 Sunseeker 3100
Old 12-24-2015, 09:08 AM   #24
Wolverine 1945's Avatar
I would say Duckogram is Right On !!!
I also run Engine & Generator a couple of times during the winter !!!
Wolverine 1945 is offline   Reply With Quote
Old 12-24-2015, 09:37 AM   #25
Former Full Timer
Duckogram's Avatar
LOL I think you are referring to a post that I deleted. I felt it did not have enough "tonal quality" for the season.
What I will post is that if one was to read their hymnal (owners manual) one would find where the manufacturer recommends filling the tank for storage!
2014 F-53 reference is on page 88.
2014 E450 reference is on page 240.
You can find it at owners.ford.com.
I'm not a mechanical engineer but I did work in a fuel testing lab back when my hair was short and I had some and I can tell you that you do not want H2O in your benzine or algae in your cooking oil. So whatever method you choose, be safe and enjoy your RV.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 12-24-2015, 09:43 AM   #26
Who Dares, Wins
doc73's Avatar
I use stabil in all gas products that sit. Keep the tanks topped off so they are ready for use. My diesel doe not sit long enough to worry, it's the DD.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
gas, storage, tank
