Old 09-02-2016, 08:25 PM   #1
Furnace not coming on
Hi: Although I have been reading posts for some time - this is my first request for assistance. Furnace stopped working just as we headed north last spring. Before putting Sunseeker 2300 into storage in anticipation of a major trip south in January I would like to get the furnace operational.
Fan works on High and Low and AC works. However when I put thermostat into furnace mode and fan on auto - I hear a click at the furnace - but the fan does not come on. Have checked furnace for dirt - appears clean.
There is power getting to furnace, which is a Suburban SF30FQ model.
Any suggestions would be greatly appreciated.
Dave Giles is offline   Reply With Quote
Old 09-03-2016, 08:28 AM   #2
If you want help I suggest you start another thread for people to respond to.
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 09-03-2016, 08:45 AM   #3
KyDan's Avatar
Moved to new thread--
Question- are you saying your furnace fan will run when fan switch is
set to ON but won't run when you try to run the furnace??
(Just wanted to make sure the fan you talk about running is the same
fan that is not running in heat mode...)
Peace!
Dan & Rita D
2004 5.3L Silverado 1500 ext. cab 2WD
Blue Ox WD hitch, AirLift load levelers
2013-41, 2014-31, 2015-40, 2016-44
