Old 12-27-2016, 07:09 PM   #1
Fuse for FR3 hitch electrics?
Have a 2017 FR3 30DS, and smacked the bottom going over a dip. Bent the plate and electrical fitting to connect to tow vehicle/trailer. Replaced connector and carefully rewired as per original. Have no power to connecter, so suspect a blown fuse.
Anyone know where the fuse box is and which fuse may be the problem? FR3 documentation I got with rig is worse than useless. Thanks.
Blue Ayes is offline   Reply With Quote
Old 12-27-2016, 07:52 PM   #2
HAPPY WHEN RV'ING
drivmsafe's Avatar
When I lost power to my trailer plug on our 2014 FR3 I did a google search for for a owners manual. I found one and it showed me what fuses where for what. I also found out that some years are different for what #fuse does what. So it's best to fine a Ford manual for your 2017.
Your fuse boxes should be; 1 to the left of the steering box, 2 in the engine compartment on the firewall above the air cleaner.
Good luck.....
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 12-28-2016, 09:48 AM   #3
Thanks. Guess it's time to Google!
Old 01-19-2017, 09:39 PM   #4
Here you go
File Type: pdf FORD 2015 FR3 MODELS FUSE BLOCK DIAGRAM.pdf (262.2 KB, 61 views)
DutchRv is offline   Reply With Quote
Old 01-19-2017, 10:11 PM   #5
And for future reference in case you don't already know by now, your 2017 FR3 is on a 2016 Ford F53 chassis, not 2017.
Mike
2015 FR3 30DS
KansasFR3 is offline   Reply With Quote
Old 01-20-2017, 08:34 AM   #6
Thanks Mike. Fixed the problem - ended up being a DFU issue (dumb freaking user).
electric, fuse, hitch
