Old 05-29-2015, 07:33 PM   #1
fpo1123's Avatar
fuse for house radio.
I blew the fuse in the house radio in a 2015 fr3. Any idea where it might be? The front radio still works fine.
MSG (Ret)
U.S. Army
Active-duty 66-92
2015 FR3 30DS
fpo1123 is offline   Reply With Quote
Old 05-29-2015, 07:56 PM   #2
I had a TT with a Jensen radio/Dvd. Blew a fuse behind the radio. Remove face plate surround...remove screws...maybe 4...radio should pull right out. Fuse in line, back of radio. Hope that helps.
martinto is online now   Reply With Quote
Old 05-30-2015, 06:56 AM   #3
fpo1123's Avatar
Pulled that and it's fine.
MSG (Ret)
U.S. Army
Active-duty 66-92
2015 FR3 30DS
Old 05-30-2015, 07:37 PM   #4
fpo1123's Avatar
Found it, direct wire to house battery under plastic cover. 15 amp.
MSG (Ret)
U.S. Army
Active-duty 66-92
2015 FR3 30DS
Old 06-01-2015, 07:04 AM   #5
Where is this fuse located, and what number is it
Walkerm25 is offline   Reply With Quote
Old 06-01-2015, 07:22 AM   #6
FPO 1123 unable to open your reply, please post it here..... Thanks
Old 06-01-2015, 07:29 AM   #7
fpo1123's Avatar
It isn't in a fuse box. It is a fuse holder that runs off the house battery's. Take the cover off the house battery's and you will see a yellow wire attached directly to the battery. There is a single fuse block with a 15 amp fuse. If that is good there is another behind the radio which takes four screws to remove the radio. Hope this helps.
Old 06-01-2015, 07:34 AM   #8
Thanks I will check there first, do you have the same furrion radio?
Old 06-01-2015, 07:50 AM   #9
fpo1123's Avatar
Yes. And TV
MSG (Ret)
U.S. Army
Active-duty 66-92
2015 FR3 30DS
Old 06-01-2015, 03:41 PM   #10
Thank you so much, we just returned home to NC, I took the battery box off and the fuse was fine, it appears the yellow wire fell off from the terminal, probably from vibration and also whoever installed it did not crimp the connector, works fine now..
fuse, radio
