Old 02-10-2015, 06:32 PM   #1
Question Fuses
Can anyone tell me where is the rear storage compartment light FUSE on the FR3 30DS.
Thanks for the info.
tinome is offline   Reply With Quote
Old 02-10-2015, 06:44 PM   #2
TURBS's Avatar
Sure it isn't a bulb?
Most of the time the lights are daisy chained and if one is out others should also be out.
Old 02-10-2015, 07:20 PM   #3
No it is not a bulb. I have caused the short while replacing the on and off switch on the storage compartment lamp assembly, now I am looking for the fuse.
Old 02-10-2015, 07:30 PM   #4
HAPPY WHEN RV'ING
drivmsafe's Avatar
Have you checked in the control panel in the bedroom?
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 02-10-2015, 07:35 PM   #5
Yes I did but there is nothing there concerning that circuit.
Old 02-10-2015, 07:47 PM   #6
HAPPY WHEN RV'ING
drivmsafe's Avatar
Fuses
The other place would be in the battery control center box in the house battery compartment
Old 02-10-2015, 07:49 PM   #7
Desert Kicker's Avatar
Fuses
There's a fuse box in the storage bay where the batteries are located. I'm not sure if the one you're looking for is in there, but it is a place to look.
Desert Kicker is offline   Reply With Quote
Old 02-10-2015, 08:04 PM   #8
HAPPY WHEN RV'ING
drivmsafe's Avatar
Fuses
If you scroll down through all the listings in the FR3 forum here, z3406 posted FR3 schematics back on 8/15/14. Open this and hit the link. You'll be directed to the schematics which you should be able to print out.
Old 02-10-2015, 08:24 PM   #9
Thanks guys, I will check that first thing in the morning.
Old 02-11-2015, 07:31 AM   #10
Online_17's Avatar
If it's just one light...bulb. if is all your basement lights, there's a fuse in the black box beside the house batteries. Disconnect ground and unscrew the cap. Use a tester on the fuses. Mine went and I seem to recall it being the 1st or 2nd fuse, moving left to right...but a tester will be sure to catch it....
Online_17 is offline   Reply With Quote
fuse
