Old 06-18-2015, 01:55 PM   #11
Jim Schings's Avatar
Thanks. You are correct. Found it.
Jim Schings is offline   Reply With Quote
Old 06-18-2015, 02:10 PM   #12
No problem! Had the same thing myself a couple weeks back took a while to find.
winojoe is offline   Reply With Quote
Old 06-20-2015, 09:41 AM   #13
FR3 Drawings
These drawings were on a previous post and contains good information about numerous items related to the FR3. Includes some electrical and plumbing and other items.
Telcoman is offline   Reply With Quote
Old 07-04-2015, 04:24 PM   #14
Antone's Avatar
Fuse for backup camera/screen
Hi, I'm hoping someone can tell me where the fuse for the backup/sideview cameras and monitor is on a 2015 FR3 30DS. I'm gettin no power to the monitor. The fuses are maddening, when the panels say "See Owner's Manual" and there is nothing in the owner's manual. It's like a sick joke.
Any help would be so appreciated!
Antone is offline   Reply With Quote
Old 07-07-2015, 09:19 PM   #15
Technorick's Avatar
Open up the radio dash and find the 8 or 15 pin monitor connector from camera multiplexer to the monitor. I suspect it has come loose.
As for fuses there are three places u will find fuse blocks in addition to those in line at the battery posts.
1. The battery control box above the dual batteries. Mentioned above
2. There are mini fuses under the dash far left down by the e brake. Try to reach them! For me to get to those I have to slide the drivers seat back recline it, lift the steering wheel and slide down upside down to reach them. I have no idea what those control, but they are all live. I suspect windshield wipers washer flashers and cruise.
3. The fr3 has a master fuse block on the outside of the fire wall in a plastic box behind the grille center. Those are listed in the F53 ford manual.
2014 FR330 DS
Technorick is offline   Reply With Quote
Old 07-07-2015, 11:13 PM   #16
Antone's Avatar
Every FR3 owner should know this!
2014 FR330 DS
TechoRick, thank you! This list every single fuse in the front end and under steering wheel! Money! I will be printing the F53 Ford Motorhome chasis manual from my binder! I will figure the camera monitor out and let you know. It was just replaced befote this trip.
Our electric step switch is not working to keep the steps down. Any ideas?
Thanks so much!
Old 10-07-2015, 06:34 PM   #17
Question Lost all appliances / Radio power on new 2016 FR3 30DS
Bringing home the new 30DS from Florida to Virginia, the Pioneer radio console with the Camera video powered down half way on the trip and wouldn't turn back on. When we finally got home, we found the AC, Microwave and all 3 TV's are also without power. The documentation from the dealer is considerably lacking any details on what fuses to look at or where they might be. Anyone know which fuse would support all of these and where it is?
Thanks - "Nubee RV owner" :-)
DreamCatcherVA is offline   Reply With Quote
Old 10-07-2015, 06:42 PM   #18
FReedom3's Avatar
Sounds ike you tripped the main breaker, in bedroom, below rear closet, farhest to the rear.
FReedom 3 Danny Mary Daisy
FReedom3 is offline   Reply With Quote
Old 10-07-2015, 08:41 PM   #19
I thought so as well. but all the breakers are in the up position. I flipped all down and back up to be sure. but no change.
Old 10-07-2015, 10:10 PM   #20
I'm not sure about the radio - i'm having that replaced on my 2016 28DS, because it died as well..
You didn't mention it, but I assume you were either on shore power or had the generator running? There is no inverter on the FR3s - you wouldn't be able to run them (or any AC-powered device) purely on battery power.
Them = Microwave, the rooftop AC, the 120v wall plugs, etc.
SEGV is offline   Reply With Quote
fuse, modifications
