Old 06-07-2015, 01:31 AM   #1
Fuses And What They Go To On Late Model 2015 FR3 30DS
Can someone identify for me what the following inline fuses go to
All are located by the coach batteries.
On the left side on battery each connected to the positive terminal
1)On blue wire with 5AMp fuse label on fuse holder. Fuse holder is blue.
2)On green wire wire with 25Amp label on fuse holder. Fuse holder is green.
3)On blue wire with 15Amp label on fuse holder. Fuse holder is blue.
On the right side on battery
1)On yellow wire with 5Amp fuse. Fuse holder is red
2)On blue wire with 5Amp fuse.
Paul
JABuyer is offline   Reply With Quote
Old 06-07-2015, 04:09 PM   #2
I can understand your questions, we recently purchased a 2015 25ds, sure wish Forest River would give you an accurate owners manual, ours is plain generic???
Walkerm25 is offline   Reply With Quote
Old 06-07-2015, 07:18 PM   #3
fpo1123's Avatar
I know the yellow with the 15 amp is the house radio. Had to replace that one.
MSG (Ret)
U.S. Army
Active-duty 66-92
2015 FR3 30DS
fpo1123 is offline   Reply With Quote
Old 06-07-2015, 07:26 PM   #4
bubbles's Avatar
Paul
Positive terminals:
1) 02 sensor
2) electric steps
3) awning
You should double check this by removing the fuse and see if the item I think it is does not work.
I Don't even want to guess at the others.
Old 06-07-2015, 08:49 PM   #5
Brewster McFrisk's Avatar
The 5 amp one is the antenna booster on mine.
Brewster McFrisk is offline   Reply With Quote
Old 06-08-2015, 12:13 PM   #6
After you figure them out clearly label them for future
Harkerr is offline   Reply With Quote
Old 06-08-2015, 01:25 PM   #7
FR3 Drawings
30DS drawings.pdf
Take a look at Page one of the attached drawing.
These drawings apply to the our FR3, not sure if they apply to the new ones.
Albert1950 is offline   Reply With Quote
Old 06-08-2015, 02:23 PM   #8
bubbles's Avatar
Originally Posted by Albert1950 View Post
Attachment 79433
This does show battery control center interconnects but does not address inline fuses connected directly to the battery stud.
Old 06-17-2015, 03:47 PM   #9
Jim Schings's Avatar
Albert, Great PDF files for the wiring. It is probably close to mine..
I have a 2014 FR3 25ft and the cab right side cigar lighter (aux 12V) is dead. I am sure it is a fuse, but have no idea where the fuse panel is. Anyone know? Apparently the dealer nor FR knows either, since they won't return calls.
Jim Schings is offline   Reply With Quote
Old 06-18-2015, 03:37 AM   #10
The fuse is attached to the wire that runs from the lighter directly behind it
winojoe is offline   Reply With Quote
fuse, modifications
