Old 01-18-2019, 09:42 PM   #1
Generator
My generator runs. But dosent seem to actually power anything. Or charge battery is there a switch somewhere I missed. I'm new to this and I've had nothing but trouble. My batteries go dead even though I'm running the generator. I have a 2019 fr3
Lyndall is offline   Reply With Quote
Old 01-18-2019, 09:49 PM   #2
Berkshire 390QS
NO3putt's Avatar
Did you check the breaker on the generator?
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
Old 01-18-2019, 09:53 PM   #3
FR3Traveler's Avatar
Is the shore power cable plugged into the electrical receptacle in the electric compartment?
Mark & Connie
FR3Traveler
2017 FR3 30 DS
2006 GMC Canyon (toad)
FR3Traveler is offline   Reply With Quote
Old 01-18-2019, 11:39 PM   #4
I didnt know it had one. I'll look first thing in al
Old 01-18-2019, 11:40 PM   #5
No. We have no ac power here
Old 01-19-2019, 01:26 AM   #6
Sagecoachdriver's Avatar
Did you find the breaker switch on the generator? My Onan 4K has the switch on the left side of the oil filler. You probably have the larger generator and it would be down there somewhere.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
Sagecoachdriver is offline   Reply With Quote
Old 01-19-2019, 07:11 AM   #7
I had the same issue with my 17FR3, I forgot i had to plug in when running generator. in the rear storage area where your shore power cable is, there is a receptacle where you plug in your power cable when running generator. hopefully this will fix issue.
wnewman53 is offline   Reply With Quote
Old 01-19-2019, 10:14 AM   #8
Lacey's Spring, AL
formerFR's Avatar
yep, one of the most common 'wonders' of the use of the generator is why the coach is still not getting any 120v power while it is running... the generator has it's own breaker(s) on the generator itself - they may be tripped...
also, some coaches require you to plug your Shore Power cable into an outlet in the shore power storage bay, in order for the generator's power to flow into the coach's electrical panel, since the coach has no internal ATS(automatic transfer switch). It's a 'manual' thing.
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx,
100,000+mi since '14, US, Alaska, Canada, now Lacey's Spring, AL : )
formerFR is online now   Reply With Quote
Old 01-19-2019, 10:35 AM   #9
cavie's Avatar
If you fill out a signature line it will print automaticly and you won't have to tell us what you have each time.
Did you find the circuit breaker in the generator???? Can you plug into shore power to charge your batteries?
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 01-19-2019, 11:22 AM   #10
2019 FR3... Didn't the dealer go over these important items and show you how they work?
I'm still amazed at the amount of folks who buy a R/V without knowing how to use items or know whether things operate correctly before ever leaving the lot?
Days Camped: '16=46 '17=30 '18=51 '19=36
generator
