Old 11-07-2014, 07:11 AM   #1
Generator exhaust extension
Anyone else install an extension on the generator exhaust pipe? The kit I see shows it the extension pipe going straight up in the air anchored to the motor home. We have the main slide in the way.
TheresiaC is offline   Reply With Quote
Old 11-07-2014, 10:20 AM   #2
HAPPY WHEN RV'ING
drivmsafe's Avatar
If you plan on using the Gen-turi extension, you'll need to add an elbow to be able to go around the slide.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 01-03-2015, 08:18 PM   #3
Technorick's Avatar
Found off the shelf parts at Auto Zone. Installed a right angle 2 and half inch pipe and a 5 ft pipe extension. Connects to the Venturi exhaust (that already had the upward facing right angle) with no modifications and allows the slide to open and run the gen with the Venturi pipe chimney connected.
I also found that raising the gen exhaust pipe was easily done. Pipe is held on to the muffler with a 2 inch clamp. Removed the top clamp, cut top of pipe back three inches, cut notch in pipe and reinstalled. The pipe hanger had to be moved up.
Technorick is offline   Reply With Quote
Old 03-18-2015, 10:20 PM   #4
What is the purpose of this ? Does it make it quieter
ikeeddy is offline   Reply With Quote
Old 03-19-2015, 10:06 AM   #5
HAPPY WHEN RV'ING
drivmsafe's Avatar
ikeeddy.. No, it does not make it any quieter. The generator exhaust on the F
R3 is right under the living room slide out. Occasionally, exhaust fumes tend to come up into the coach. The Gen-turi takes the exhaust up over the coach to eliminate this problem, but, an extension is needed in order to attach it so's not to hit the slide.
Old 03-20-2015, 08:48 PM   #6
Technorick's Avatar
Example of extension to go around the slide out. Click image for larger version
Name:	ImageUploadedByForest River Forums1426902434.924614.jpg
The upright portion is an off the shelf Venturi exhaust kit.
2014 FR330 DS
Old 03-23-2015, 12:21 PM   #7
thanks for the info, poorly designed location for exhaust
Old 03-25-2015, 04:38 PM   #8
AngioTech55's Avatar
You guys are awesome. I bought the gen Turi before I bought my FR3 and was then disappointed when I saw where the exhaust was located. The pictures were a huge help. 👍
AngioTech55 is offline   Reply With Quote
generator
