Old 04-06-2017, 10:01 PM   #1
Antone's Avatar
Generator oil
Looking for recommendations for generator oil.
Thanks!
Antone is offline   Reply With Quote
Old 04-07-2017, 01:15 AM   #2
sgtlm17's Avatar
My personal preference is Castrol SAE 30. That is provided you only run generator in the warmer months with outside Temps 40 or warmer. If you plan to use generator also in colder weather use a 15w40.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 04-07-2017, 04:46 AM   #3
Gohawks's Avatar
We live in Illinois and exercise generator monthly in the winter. I use 15w40.
Mike
2015 Georgetown 351DS
Gohawks is offline   Reply With Quote
Old 04-07-2017, 05:40 AM   #4
World Wide Wanderer
wahoonc's Avatar
According to my manual 30 wt for warm weather use... I live in the Deep South so 30 wt it is. I used the stuff from WM. As long as it has the correct SAE spec on it, brand doesn't really matter.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 04-07-2017, 10:09 AM   #5
Antone's Avatar
Just regular motor oil? Or 4-stroke?
Old 04-07-2017, 10:10 AM   #6
Antone's Avatar
Got a lot of dry camping coming up, I just want to be prepared.
Old 04-07-2017, 10:52 AM   #7
World Wide Wanderer
wahoonc's Avatar
The generator I use is 4 stroke, oil goes in the sump. I use the WM brand Permatech, or whatever other brand that meets the ratings. I buy 2 quarts, takes 1.6 to fill mine up, the leftover is for topping up if and when necessary.
Aaron
Aaron & Rhonda
Old 04-09-2017, 08:01 AM   #8
Duckogram's Avatar
Onan 4000 air cooled genset comes with 15w-40 from
the factory. The manual reads that you can use SAE 30W. I tried
that but starting was sluggish when up North and nights get cool.
15w-40 is labled as a Diesel Oil however the specs meet the Onan requirements.
I change the oil every 100 hrs using a transfer pump from the 5 qt
jug the oil comes in. Wallymart is a good place to get the sauce.
ILB ( | )
Old 04-10-2017, 10:18 AM   #9
Antone's Avatar
Thank you. I saw that in the manual too. I will go 15w-40.
Old 04-10-2017, 10:23 AM   #10
Prime Member
I just changed my generator oil with Mobil 1 10W-30 synthetic.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
generator
