Old 06-05-2016, 03:02 PM   #21
Lexi2007's Avatar
Check the oil level and keep your gasoline tank topped off. We discovered that our gen will simply quit if the oil level or fuel level drops. Good luck.
Ken & Val [Lexi's mom] Moczygemba & Tori the dog
Adkins, TX
2017 Coachmen Concord 300 DS [Lexi III]
Lexi2007 is offline   Reply With Quote
Old 06-06-2016, 05:21 AM   #22
waiter21's Avatar
Sounds like a fuel pump issue. They are reasonably easy to replace, The aftermarket version from Airtek is about 1/2 the cost of the Onan version.
While your at it, may as well replace the fuel filter and, spark plug, and air filter. I just did all this on mine:
Onan Microquiet 4k Tuneup | 2001 Coachmen Mirada 300QB
ALSO
You may consider adding vents to your generator compartment cover. These will help when driving and also stationery.
Generator Compartment vents | 2001 Coachmen Mirada 300QB
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 06-13-2016, 08:31 AM   #23
my 2016 FR3 30DS does the same thing, Saw that the 2017 model now has a vent with a boot inside to let air into the generator. FR probably made the change due to over heating. I will be installing a vent in my Gen door.
Fireretiredgfd is offline   Reply With Quote
generator
