Old 06-19-2017, 09:33 PM   #1
bes
Genset shuttin down--door damaged by heat
Hey guys, I know this topic has been discussed in Georgetown, but anyone else in the SW having genset issues due to the desert heat? On the road the genset shuts down after an hour or two. The panel door to the coach, is starting to get funky inside from the heat--the coating on the inside of the door has begun to bubble and disfigure.....must be excessive heat from the genset and chassis?
This is not due to the fuel tank dropping past a certain point, I had 4/5th of a tank last weekend and the genset (and air) was off when we got to our site about 40 minutes from home. Are the new models vented? I have a 2015 28ds. BTW--I do not think we have this issue once parked.
Thx Barry
bes is offline   Reply With Quote
Old 06-20-2017, 02:01 AM   #2
rk06382's Avatar
Thx Barry
Our 2018 FR3 28DS has a vent on the Generator door.
Robert
2018 FR3 28DS | Boondock 99% of the time
Samlex EVO-3012 Inverter/Charger | 600ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | SnapPads | SumoSprings | Koni Shocks | RVLock
Solar Power & Battle Born batteries
rk06382 is online now   Reply With Quote
Old 06-20-2017, 01:31 PM   #3
I believe, FR started putting vents on the doors for 2016/2017. We called them and they sent us a vent and instructions. My husband was able to install the vent without any problem.
MGWS is offline   Reply With Quote
Old 06-20-2017, 02:00 PM   #4
bes
Yup
I emailed FR yesterday and got a response this AM--sending out the vent for me to install. Customer service way better than I expected The install was easy?
Old 06-20-2017, 02:10 PM   #5
Yes, my husband cut it with a dremel and it was easy to slide in place.
Old 06-20-2017, 02:16 PM   #6
Who did you contact at FR to get these vent parts ?
2014 SUNSEEKER 3010DS
TOADS, 2012 FOCUS OR 1998 JEEP WRANGLER,
Kevin & Judy is offline   Reply With Quote
Old 06-20-2017, 02:22 PM   #7
bes
Celestino Lopez <CLopez@forestriverinc.com>
Old 06-20-2017, 06:25 PM   #8
I contacted the customer service number for Forest River and asked for the FR3 department.
Old 06-20-2017, 09:00 PM   #9
HAPPY WHEN RV'ING
drivmsafe's Avatar
I added these marine vents on our 2014 30DS Click image for larger version
ID:	142128compartment door and have had no overheating problems.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 06-22-2017, 07:35 AM   #10
Wolverine 1945's Avatar
Has anyone ever heard of this problem with a Sunseeker,,, out Generator space is open on the bottom !!!
Wolverine 1945 is offline   Reply With Quote
Old 06-22-2017, 04:02 PM   #11
If you have an Onan generator with a side door covering the intake vent (even if there is a ~2" space between the door, you'll probably have issues. Your gen will vapor lock causing it to starve for fuel until it cools down. Then it'll start after a cool down period.
Mike
2015 FR3 30DS
KansasFR3 is offline   Reply With Quote
Old 06-23-2017, 06:16 AM   #12
Sounds like it might be a good idea to bungy Gen door open when parked !!!
Maybe I will even add a door clip to hold the door open ???
door
