Old 08-21-2018, 09:42 PM   #1
Gfi tripped
GFI tripped and have disconnected the down line to see if anything beyond gfi was shorted. Still gfi won't reset. Thinking it must be in the panel or somewhere between the panel to the gfi. BTW, new gfi and has the green light showing on the gfi. Any hints to the solution?
anolefan4life is offline   Reply With Quote
Old 08-21-2018, 10:08 PM   #2
Coach
You say new GFI, is this replacing one that tripped previously?
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 08-21-2018, 10:32 PM   #3
cavie's Avatar
Are you at home and plugged into a GFI circuit? 2 gfi's in series don't play nice.
Unplug anything downstream of the GFI. bathroom, kitchen, outside. Any outlet within 6' of water. Also storage areas.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 08-23-2018, 06:58 AM   #4
Replaced the old gfi just to make sure. Unplugged everything downstream. Tomorrow, will open up the panel and check for loose wiring, breaker, etc. Crissing my fingers.
Old 08-23-2018, 07:06 AM   #5
cavie's Avatar
After you have checked the panel then go downstream and pull every outlet and look for loose wiring or grounds touching hot. or neutral. When you replaced the GFI did you take note of Line and Load connections? If you find no Loose connections, Go back to the GFI and disconnect the load side. The outlet should work. Then go down the line again disconnecting one pair of wires. Think daisy changed. this is how you find a hidden connection. Electric troubleshooting 101.
You didn't answer the question. Are you plugged into a GFI circuit? Do you have power at the GFI after it is tripped?
Old 08-23-2018, 09:45 AM   #6
I don't believe so. I spoke with a mobile repairman and he said that it I disconnect the down stream hotwire and the gfi still doesn't reset, the problem is most likely between the panel and the gfi. That's my next step. I'm glad to get any suggestions to resolve this pesky problem.
Old 08-23-2018, 09:47 AM   #7
The down stream hot wire at the gfi I meant to add.
Old 08-23-2018, 09:58 AM   #8
Flybob's Avatar
The GFCI doesn't look up stream. In simple terms, it looks at the current flowing into it from the hot side and compares it with the current flowing back in the neutral side and if they differ by a preset amount it trips.
Check for moisture or spider webs in outlets especially any outside. Spider webs will attract moisture and provide a high resistance bypass path that will not trip a breaker, but will trip a GFCI.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-23-2018, 10:08 AM   #9
cavie's Avatar
Do you have power at the GFI Breaker? The GFI outlet must have power to reset.
That's why we need to know what you ate plugged into? Pleas answer the questions we ask so we can help.
Old 08-24-2018, 06:46 AM   #10
Yes. There is a green light on the gfi.
Old 08-24-2018, 07:09 AM   #11
cavie's Avatar
So, if you disconnect the load wires from the GFI does it reset?
Old 08-24-2018, 08:39 AM   #12
Negative. This is a new gfi also. I'm going to check out the panel to make sure there isn't a loose wire on the breaker.
Old 08-24-2018, 09:34 AM   #13
Not now. Have been running the genny. The mobile tech I called doesn't think it's down the line since I disconnected the down stream hot wire and it wouldn't reset when under power?
Old 08-24-2018, 09:50 AM   #14
Honest Abe's Avatar
Does the GFI fail to reset on shore power, as well as genset power?
1stSgt Abe Aviles
USMC Retired
2014 FR3 25DS
San Pedro, CA
Honest Abe is offline   Reply With Quote
Old 08-24-2018, 10:53 AM   #15
cavie's Avatar
To check a GFI you must disconnect both hit and neutral. They are different than a standard outlet. Hook up JUST the GFI to the LINE pair if wires and see if it resets. This is electric troubleshooting 101.
Old 08-24-2018, 04:23 PM   #16
Thanks.
