Old 06-12-2017, 07:50 PM   #1
Good idea or bad? Hose quick disconnects...
so i added hose quick disconnects to the city water, fresh water fill, and black tank flush inputs on the side of the coach. i think these are going to work well -- so i won't have to screw/unscrew the hose connections off every time. on my 29DS, the input connections are plastic and i can see them failing after a bunch of connecting and disconnecting. also added quick disconnects to the fresh water input hose around connection and filter...finally, found rubber stoppers to use in the holes to plug when not in use.
do y'all use them too?
b
Retired USAF
2018 FR3 29DS
Calls Space Coast of Florida home...but Roll Tide
bamagrad1992 is offline   Reply With Quote
Old 06-12-2017, 08:16 PM   #2
gomatthew's Avatar
Pics and links to which ones you chose? That's a great idea I think
gomatthew is offline   Reply With Quote
Old 06-12-2017, 08:17 PM   #3
dieselbobcat's Avatar
Tried them and noticed a major decrease in flow. YMMV... they do make life easier though.
Your thoughts are correct, they plastic ones will fail after a few seasons. I have replaced mine already.
2014 Rockwood Ultralight 8312SS Diamond Edition
2016 F350 Lariat Ultimate Super Duty Crew Cab 4X4
Northern NJ - God Bless America!
dieselbobcat is offline   Reply With Quote
Old 06-12-2017, 08:24 PM   #4
Have used the Brass Quick Ds for years,very few seal failures! Even place one on the Campground City Water Supply,just "Don't Forget to Remove and take it withyou"! Youroo!!
Old 06-12-2017, 08:50 PM   #5
am using these...
https://www.lowes.com/pd/Yardsmith-Y...r-Set/50328307
i have three male ends on the water connects to the coach. Lowes sells the set or individual male/female connectors so you can mix/match as needed to your needs. no drips, leaks -- and super easy to connect.
NOT using on the connection to city water. leaving that one manual as i know i will surely forget them when packing up!
best of luck all
b
Retired USAF
2018 FR3 29DS
Old 06-12-2017, 08:52 PM   #6
small black rubber stoppers were found in the hardware section. use the 3/8"-- i think -- that fit perfect in the male end of the disconnect...
just to keep the holes covered and the critters out
b
Retired USAF
2018 FR3 29DS
Old 06-12-2017, 09:07 PM   #7
Canadian Member
I had the same idea and bought these ones but haven't installed them yet.
https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
Old 06-12-2017, 09:18 PM   #8
W5CI's Avatar
I have been using the Brass quick disconnects for years now
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 44
W5CI is offline   Reply With Quote
Old 06-13-2017, 12:18 PM   #9
7 Year Class A RV'er
I've looked at them and only had one question that maybe someone here can answer for me. When I connect to the water source at a campground, the first thing I do is run the water until the hose is full, then connect it to the coach. That gets all (or most) of the air out of the line as well as flushing out any stale water that may be in there from the last use. On a side note, I carry a spray bottle of bleach water that I spray both ends of the hose and the connections with prior to connecting (seen too many people playing with hose bibs and their black water hoses at the same time!). With the quick disconnects, how do you make sure you're not pushing a great deal of air into your piping system, which then causes issues when some items, especially tankless water heaters?
2015 Legacy SR340 360RB
Old 06-13-2017, 12:52 PM   #10
hkreck's Avatar
The hose connection has an open discharge, it's just made for a quick connection, so you should be able to continue doing things your way still. Just hook it up after filling the hose.
Henry & Tena
hkreck is offline   Reply With Quote
Old 06-13-2017, 01:56 PM   #11
I have used them, but they may cut down on your water pressure, depending on Campground pressure. I ended up attaching short hoses to each with a y with cut offs. Works great & no pressure loss.
redleg719 is offline   Reply With Quote
Old 06-13-2017, 02:49 PM   #12
I have been using them for years and they work fine. I do keep a water pressure gauge on the incoming water though as pressure can be a problem down the road. Actually I turn off water each time we go out to prevent any uncalled for accidents (like a pipe breaking)
Larry Roth is offline   Reply With Quote
Old 06-13-2017, 03:29 PM   #13
NorSnrub's Avatar
I use them all the connections. Bought most of them from Harbor freight. I put a 1/2 inch of old hose on the fresh water and the black flush and put the cap tat came with the trailor on it.
NorSnrub is offline   Reply With Quote
Old 06-13-2017, 03:45 PM   #14
Iwannacamp's Avatar
I don't have quick disconnects... I have thought about it. I always turn on the water before connecting...flush that baby out...in case.
2017 Puma 297RLSS
Old 06-13-2017, 06:36 PM   #15
RVBuff's Avatar
I had the same concern about the plastic connector on my fresh water intake, so I installed quick connects about eight years ago and have never had a problem. I also assembled a dummy quick connect plug and cap to protect the inlet when on the road. I also purchased a standard garden hose nozzle and equipped it with a quick connect, which I can use with my fresh water hose whenever needed without having to screw or unscrew anything. It all works for me.
RVBuff is online now   Reply With Quote
Old 06-13-2017, 06:43 PM   #16
Mine are plastic so I put the quick connects on them but they still leak. I need to figure out how to replace the pieces from the factory that are plastic.
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=57 '19=47
Electra glide is offline   Reply With Quote
Old 06-13-2017, 06:51 PM   #17
asquared's Avatar
We use them too.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 06-13-2017, 06:57 PM   #18
I Break Everything
mikel68's Avatar
I always thought about using these, for the last 10 or so years. I did finally buy some about a month ago, and then used them this weekend.
GOOD GOD why was I so stupid ten years ago! 2 seconds.
mk
2015 Georgetown Forest River 351DS Class A
2008 Keystone Cougar 293SAB 5th Wheel
2007 Jay Flight 30.5RLS 5th Wheel
2006 Jay Flight 29BHS TT
mikel68 is offline   Reply With Quote
Old 06-13-2017, 07:10 PM   #19
Better late than never Mike. Quick connects on everything for me.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 06-13-2017, 07:13 PM   #20
We did this mod this year - I can't believe how much time it saves on hooking up - trying to get the hose at the right angle to screw in had been a nightmare.
Also added the 90 degree elbow - that way when you unhook the hose it doesn't dump all the water into the compartment. So that's cool.
I used brass quick connects from camco - they've worked well so far.
2015 Georgetown 351DS
2016 Jeep Wrangler Unlimited Sahara
Chris, Garren (humans)
Edgar & Carlos (felines)
RIP Sophie, the sweetest cat ever.
ChrisAndGarren is offline   Reply With Quote
