Old 05-31-2018, 12:26 PM   #1
Grey water problem
Anyone have trouble with there grey water draining.Right from New had a problem with it being plugged.I think when they drilled holes in the tank for inlet and outlet they must of left the plastic disks in tank that float around and cause problems from time to time.Now tank is full sinks backing up and no other way than take out the gate valve and get wet after clearing the clog...
lazbo is offline   Reply With Quote
Old 05-31-2018, 12:30 PM   #2
construction debris in the tanks is a pretty common thread. At least its grey water and not black. Does it drain at all? Let it drain slow some place safe with no line behind you at the dumpstation.
Kimber45 is offline   Reply With Quote
Old 05-31-2018, 12:34 PM   #3
Exceptionally slow..I replaced the gate valve but not sure if the seals are seated...but no leaks and because I was haveing a problem with the gaskets I broke off an ear from the valve but worked my way around that problem
Old 05-31-2018, 12:39 PM   #4
Er broke off an ear from the flange
grey water, water
