Old 08-25-2014, 08:00 AM   #1
Hard Starting Generator fix.
I was taking me longer than I thought it should to get my generator to start. Looking thru the owners manual I found out why. I was not priming the generator fuel system before cranking it over. To prime the generator go to the motor home control panel and hold down the generator button in the OFF position about 30 seconds. After holding it down for a few seconds the bulb in the Gen switch will illuminate and you may hear the fuel pump on the generator switch on. After priming it starts right up now.
z3406 is offline   Reply With Quote
Old 08-25-2014, 11:54 AM   #2
mud yapster's Avatar
LOL, I was lucky and the dealer showed me that or I would have done the same thing before I read my book on it. I was used to my old pull start so I just happened to ask how to start it before we left the dealer when we bought it.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 08-25-2014, 12:13 PM   #3
Motoring
grotto69's Avatar
Mine still takes 3 or 4 tries even though I'm holding it down. Maybe I need to hold it down longer
grotto69 is offline   Reply With Quote
Old 08-26-2014, 08:54 AM   #4
Yes, hold it down for 30-45 seconds. My generator repair guy told me that there's no issue with holding it down for a long time. It won't flood.
Also, keep the button depressed until the generator is fully running. Also, when shutting down, keep button depressed until system is completely off.
He said that saves valve repairs down the line.
hillcountry is offline   Reply With Quote
Old 08-26-2014, 07:03 PM   #5
Good advice ,just went thru the same thing !! Thanks for the info
bigdocron is offline   Reply With Quote
Old 08-26-2014, 08:17 PM   #6
rbetzwieser's Avatar
If it still starts hard after you prime it may be a choke issue. My choke linkage was binding. Fixed it and it starts beautiful!
rbetzwieser is offline   Reply With Quote
Old 08-26-2014, 08:27 PM   #7
Online_17's Avatar
I took mine to a Cummins Dealer. There was a recall part put on the fuel pump. No more issues. Done in an hour and free to repair . Call Cummins 1-800 and they will hook you up, amazing service! ( full 3 yr warranty on Gen)
Online_17 is offline   Reply With Quote
generator
