wow that is a large "portable " heater you have there! I also keep my coach winterized when Parked at home, and set the portable digital heater to come on at 42 degrees , it is only 8 inches square and about 4 inches thick. I go check it periodically in the winter time and coach is always around 45 degrees even when the temp is in the high teens out side. I do keep my rv under metal rv cover that is open on the ends and the sides- this probably helps a little. guess I am lucky, but have never blown a circuit breaker with mine, It is rated 1400 watts. Have used microwave at same time, think they are on different circuit though.
