Old 08-05-2016, 08:49 PM   #1
HELP! Bedslide:(
1 week old 2015 28DS!!!!! (first owner, obviously warranty)
Still prepping for maiden voyage. Rear slide comes in but not out. Ratcheting sound, no movement. Have non refundable reservations for Friday the 25th in exactly 3 weeks from now.
I don't see anything wrong at the hardware? See pics...
I refuse to go back to where I purchased, CW. (it is far, and they don't no much about camping gear in general) Rather have FR send me the stuff so I can fix myself. Thoughts?
Also, Can I manually take the slide out, so we can sleep in it in 3 weeks from now, if not resolved by then?
BTW, this does not affect my love for my new RV!
ID:	116410   Click image for larger version
ID:	116411   Click image for larger version
DutchRv is offline   Reply With Quote
Old 08-06-2016, 08:26 AM   #2
niedobry1's Avatar
Your gearbox has a broken tooth and needs replaced. It happened to us. We endured a couple weeks on the road with the slider in. I watched our mobile repairman fix it in 2-3 hours. The hardest part seemed to be adjusting the cables after replacing the gearbox. Beware I had one RV dealer tell me that the motor and gear come in one unit. Not true. If you are in time constraint you might want to deal directly with the slide manufacturer and not Forest River.
niedobry1 is offline   Reply With Quote
Old 08-06-2016, 08:28 AM   #3
niedobry1's Avatar
If you are near Stuart Florida I can give you a great mobile repair service.
Old 08-06-2016, 09:08 AM   #4
ilmor's Avatar
Gawd that system looks awful.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 08-06-2016, 09:16 AM   #5
grumpy0374's Avatar
X2. Never saw/observed what type systems you big rig owners have on those slides.
Looks like something that supports the Brooklyn Bridge. No wonder there are so many posts about problems.
Grumpy
Steve & Cheryl + Charlie & Casey, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
Camping trips this year so far...8
Days camping...75
grumpy0374 is offline   Reply With Quote
Old 08-06-2016, 09:20 AM   #6
Curiouser and Curiouser
When we called Forest River over the same issue, the warranty representative advised us to ask the campground host for the name of a mobile RV service or alternatively we could look ahead and schedule an appointment at an RV service establishment along our route. Forest River said they would send the parts needed (I can't remember if it was overnight or two days) to the location we selected (at our current campground or somewhere else along our route). We would then pay for the repairs and parts, and Forest River would reimburse us. Really can't ask for much better service than that! The rep also told us how to use the tool provided in all FR3s to move the slides in and out using a drill so that we could continue our trip moving the slide in and out manually. Suggest you call Forest River and ask for the warranty rep for FR3s. There is one for the east side of the country and one for the west side. P.S. We didn't let this spoil our trip. There is also a great thread on this that goes into much detail (with pictures) which might help. I will look it up and provide in the following post. We too suffered through some early problems with our FR3 - but once we got past these, it has been a pleasure - we love our FR3.
Finch is offline   Reply With Quote
Old 08-06-2016, 09:22 AM   #7
Help from the forum
The thread is entitled: HELP!! Living room slide not working
Old 08-06-2016, 10:11 AM   #8
niedobry1's Avatar
The drill does not work if you have a broken gear tooth.
Old 08-06-2016, 10:14 AM   #9
Is it safe/ok to push out manually, and retract with the motor after a weekend camping?
Old 08-06-2016, 10:19 AM   #10
mcnabbwr's Avatar
On mine the small shaft between the motor and gear box broke. If that's the case depending on size you can use either 1/8 or 3/16 key stock and make a new shaft. Remove the motor to check.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
bed, beds, slide
