Old 08-27-2015, 08:43 AM   #1
Help! Dump valve problems
I have a 2015 FR3 30 DS. Both the 3 inch and 1 1/2 inch plastic compression flanges that connect around the valves were damaged - probably ran over something that hit the outside dump fitting.
How do you dis-assemble the fittings to replace the compression flanges?
I believe the entire unit is called a double Ell waste vale unit.
Any help appreciated.
Phunter3 is offline   Reply With Quote
Old 08-28-2015, 07:45 AM   #2
You can't replace just the flanges. You have to replace the "Y" fitting. I too ran over something an broke mine. Went to a local RV store an got a "Y" fitting. I did not extend it down through the floor. Got a clear 3 inch straight coupling and when I hook the sewer hose I just fit it up through the hole in the bottom.
WVFR3 is offline   Reply With Quote
Old 08-28-2015, 06:41 PM   #3
Separation Anxiety
Is there any way to separate the "Y" assembly without cutting it off?
Old 08-28-2015, 08:28 PM   #4
Brewster McFrisk's Avatar
Yes, you can notch it and peel it off in small 1" sections
Brewster McFrisk is offline   Reply With Quote
Old 08-29-2015, 07:42 AM   #5
Smile
That fitting was a problem in my FR3, too. I ended up putting in a macerator system that's completely within the compartment and run a hose through, like WVFR3. Works great and no more worry about damaging the pipe.
Jay & Jane
2014 FR3 30DS
FL & MN
Live Aloha
spicyrv is offline   Reply With Quote
