Old 08-03-2017, 09:46 PM   #1
Help! Jacks won't go down
2015 fr3
colourful64 is offline   Reply With Quote
Old 08-03-2017, 09:50 PM   #2
Knoxie89's Avatar
Originally Posted by colourful64 View Post
2015 fr3
Parking brake set?
Parking brake sensor working?
Hydraulic oil full?
Enough voltage?
FR3 Fuelly
Knoxie89 is offline   Reply With Quote
Old 08-03-2017, 10:03 PM   #3
The generator is on.... we checked the sail switch ... and took the four square screws out of the switch box and disconnected it. Still nothing
Old 08-03-2017, 10:55 PM   #4
leisurelarry's Avatar
I have to have the engine running when I use my jacks.
leisurelarry is offline   Reply With Quote
Old 08-04-2017, 12:04 AM   #5
Engine is running
Old 08-04-2017, 12:12 AM   #6
Antone's Avatar
You can try to lift them manually with the switches in the hydraulic area. It's located near the propane tank I believe. I did this for a fellow FR3 owner with instructions from his mechanic over the phone. I wish I had a picture to show you.
Antone is offline   Reply With Quote
Old 08-04-2017, 12:37 AM   #7
I had a similar occurrence on my 2015 30DS. Jacks would not drop. Problem was due to wire harness being full of water. Separated the harness, sprayed interior connections with WD40. Cured the problem immediately.
Old 08-04-2017, 06:28 AM   #8
Carl17's Avatar
jacks
You will need a drill and a Allen wench cant remember size of socket and extension . but you can manual run jacks up and down from pump and value.
Go to manufacturers web site for pictures and detailed instructions . extension must fit into drill to run motor. then you turn values with allen wrench . (cap on end of motor covers drive for motor) Good luck
Carl & Bette
2018 Leprechaun
NEW YORK
Carl17 is offline   Reply With Quote
Old 08-05-2017, 11:24 AM   #9
HAPPY WHEN RV'ING
drivmsafe's Avatar
2015 fr3
Have you checked the trip breaker in the battery compartment?
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 08-05-2017, 12:03 PM   #10
StephanFR3's Avatar
Go to lci and download the manual for the jacks.
StephanFR3 is offline   Reply With Quote
jacks
