Old 06-09-2016, 05:42 PM   #1
Tents2RV
HELP!! Living room slide not working
On our way home from 8 day trip. Living room slide goes out 6 inches and stops with a ratcheting sound. This is in an FR3 30DS. Any suggestions would be appreciated. (We are 2 days from home.) Thanks
c0nnd0r is offline   Reply With Quote
Old 06-09-2016, 08:13 PM   #2
Technorick's Avatar
In 2014 models there was a problem where a bad batch of motors had bad sprockets and some would break a tooth. If it's grinding the motor is turning and you have power. I've read that you can human assist by pushing in the room from outside while another person holds down the button. That would get you home. I'd bet you will find its the motor gear tooth. Good luck.
Technorick is offline   Reply With Quote
Old 06-09-2016, 08:25 PM   #3
Tents2RV
Thanks Technorick. That is what I think it is too. I failed to mention that the motor will bring the slide in. So at least it's not hanging out, allowing us to still travel. I also failed to mention that this is a 2015 model. I'll post the fix when it happens.
Old 06-10-2016, 11:08 AM   #4
JerseyGuy's Avatar
The gear shears offClick image for larger version
Name:	ImageUploadedByForest River Forums1465574910.779777.jpg
ID:	110705. I had it happen too.
2014 FR3 30DS In New Jersey
JerseyGuy is offline   Reply With Quote
Old 06-10-2016, 11:10 AM   #5
JerseyGuy's Avatar
I opened up the gear box after my dealer replaced the assembly. It is the gear, not the motor that dies.
Old 06-10-2016, 12:19 PM   #6
twojump36's Avatar
Dang... I'm leaving for an 8 day trip next Saturday.... I've been dreading to hear the 2015's (like mine) are having this problem too....
2015 FR3 30 DS
1995 Wrangler
Miles 4600
Days Camped 48
twojump36 is offline   Reply With Quote
Old 06-10-2016, 08:03 PM   #7
Tents2RV
Thanks for the info JerseyGuy and sorry to darken your day twojump36.
Old 06-11-2016, 07:41 AM   #8
wayne and sherry's Avatar
The gears in that photo look like they are made from the cheapest material that forest river could find. I'll bet they spent more money to find the junkyest material than it would have cost to just use a standard material that was already in production.
wayne and sherry is offline   Reply With Quote
Old 06-11-2016, 07:44 AM   #9
Let me ask ya all this... When you drive out your slide or in, when you reach your end point, how much load up are you allowing before you take your finger off the switch? As soon as l hear the motor start to load up l stop!
Old 06-11-2016, 08:31 AM   #10
dcheatwood's Avatar
Happened to my brother. He held the power button while we pushed slide in and out. Managed to get by for the week. Good luck.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
roo, slide
