Old 03-28-2015, 07:36 AM   #11
Is it just a bulb issue or would you have to replace the entire light? Like can you just buy a stronger bulb to replace the stock? I ask because I at night a lot.
gr8daneNJ is offline   Reply With Quote
Old 03-28-2015, 07:40 AM   #12
Carl17's Avatar
The problem is some times you have to drive a night. But consider we all have spent the best part of 100 thousand and have these very big safety problems lights , Handing , fix handing on my own in Florida these things Forest River should have done. I have been a CDL driver for 40 years not first rodeo these thing are not right.
Carl17 is offline   Reply With Quote
Old 03-28-2015, 08:18 AM   #13
Has anybody fixed this, I have not taken delivery yet and I know I can get dealer to swap new lights. What has worked? Part # ?
Old 03-28-2015, 08:40 AM   #14
Carl17's Avatar
Thumbs up
Lights may just be adjustment. Handle have dealer move sway bar links on front and back to inner holes to increase roll residence you will be very happy or do your self .
Old 03-28-2015, 05:52 PM   #15
The lamps that comes the Gtown are the phillips H9....has any one found a brighter lamp with out a lot of expence or is there an a
Dogpound is offline   Reply With Quote
Old 03-28-2015, 06:08 PM   #16
HONDAMAN174's Avatar
Help low beam headlights
Whoops- had posted a solution then noticed I had wrong information
Just glad to get away
Old 03-28-2015, 10:13 PM   #17
Vince and Charlette's Avatar
I just bought a 2015 Georgetown 364TS in January and took a two week trip. Lights were terrible at night. Center of the road ahead was pitch black. On close inspection, I saw that the rim of the high beam light fixture protruded forward so far that it blocked out part of the headlight beam! Since I consider this a safety hazard, possibly worthy of a recall, I contacted the FR tech rep who asked for pictures, which I sent mid Feb. Haven't heard a peep since. If others think their problem may be the same, we need to turn up the heat with FR and find out their current position on this important issue. (I don't know if this may be an issue on other than Georgetowns.)
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
Old 03-29-2015, 09:33 AM   #18
Carl17's Avatar
1. lights are way out of adjustment ( rv needs to be loaded when done)
2. Light bulbs could be brighter
Still have jet lag from trip when weather inproves will test drive play with adjustments or just take back to dealer.
Old 03-29-2015, 03:03 PM   #19
Carl17, If you find that an adjustment solves the problem, please let us know how to do it.
2018 Berkshire 38A
Old 03-29-2015, 04:35 PM   #20
I not sure if there is an adjustment....I. believe that it is the system FR uses on the Georgetown... l plan to call. Ford and FR Monday... I,'ve got do something my lights just reach out so far...sometimes you just have to drive at night...there is an HID kit however I,m not sure if they will adapt to the system and I surely don,t to screw something up
light
