Old 09-25-2015, 02:32 PM   #41
HAPPY WHEN RV'ING
drivmsafe's Avatar
Originally Posted by b1barnes View Post
Mine is a 2015 and as Frog above said 2007 to 2010 Silverado assemblies fit. It is the whole assembly. You do loose the LED's in the headlights. FR said the wire harness is plug and play.
I'd be very interested hearing how the install, plug and play goes b1. Please keep us posted after you get the assemblies.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 09-25-2015, 07:44 PM   #42
Question. When I turn on the LED lights on the console the lights on my awning comes on but so do my headlights. Is this normal and wouldn't this run the battery down. Thanks for your input. I have a FR3
angelicashelties is offline   Reply With Quote
Old 09-25-2015, 07:59 PM   #43
b1barnes,
Who did contact at FR I would like to explore this option and see if they would be willing to help me out with the headlights for my 2014.
Jmluka is offline   Reply With Quote
Old 09-29-2015, 08:29 AM   #44
We had the same issue. Contacted FR3 servie, complained about the issue and they replaced the headlights. FR3 service CR#3 Elkhart,IN
J1BCU is offline   Reply With Quote
Old 09-29-2015, 09:49 AM   #45
@angelicashelties, the way FR did the earlier models was to have the headlight LED halos come on with the awning LEDs. It'll only run down your house batteries, but their LEDs and they don't use much power. Some people just cut the wire to the LED Halos and put heatshrink over the wire so they never come on or tie them to the head light circuit. Couple ways to do without them if you choose to. I thought they were too bright, so I installed a resistor to step down the voltage. But I'll probably change out the whole headlight assy to the Silverado setup to get brighter headlights. Which they won't have the halo lights to worry about then.
KansasFR3 is offline   Reply With Quote
Old 09-29-2015, 08:46 PM   #46
Vince and Charlette's Avatar
Help low beam headlights
For what it's worth in this discussion - I had an exchange with the FR tech rep on my GT headlights. After all was said and done, it turned out both of my headlights were pointed so far off the road that it created a dangerous dark area in front of us. It appears that they aren't adjusted after installation.
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
Old 09-30-2015, 09:42 AM   #47
After three day of phone tag I got it touch with a service rep and explained about the headlights. He agreed to send a set of Silverado headlights as a replacement.
Old 09-30-2015, 10:08 AM   #48
StephanFR3's Avatar
How old is your FR3?
StephanFR3 is offline   Reply With Quote
Old 09-30-2015, 11:22 AM   #49
HAPPY WHEN RV'ING
drivmsafe's Avatar
I'd be curious to know if any of you that received, or will be receiving, replacement headlights from FR are out of warranty?
Old 09-30-2015, 11:39 AM   #50
I own a 2014 for about 18 months, it is outside of the warranty. FR did point out to me that I was out of warranty period, but I can't say why they agreed to replace. I did point out that I replaced the bulbs with a silver stars and adjusted the headlights but they were still not giving enough light to drive down the road. The end result is up until my last two trips I did not do any night driving and found out that if I wasn't running the high beams I couldn't see the road.
I will say this about FR, besides finding it tough to get in touch with, when I do there hasn't been an issue that the haven't taken care of or led me in the the right direction to take care of it myself. What we all have to remember is that the Fr3 is still a new line and they are listening to us and making fixes as they go.
light
