Old 10-24-2017, 07:01 PM   #1
Goofy1's Avatar
Help! No pwr to thermostat 30DS
Help, we are in Indianapolis for our first cold night of camping. And everything seems to be working except that the Thermostat has no power to it! Iíve cycled all the circuit breakerís and checked the three fuses that seem to have anything to do with it. Still no luck. Whatís next?
2017 FR3 30DS
Retired MSG from US Army
Goofy1 is offline   Reply With Quote
Old 10-24-2017, 07:04 PM   #2
Everything else is working? If so you have 12v power. Only thing I know to do is pull the cover on the thermostat and check the voltage to it.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
mwdilday is offline   Reply With Quote
Old 10-25-2017, 06:47 AM   #3
Goofy1's Avatar
We made it through the night but still no power to the thermostat.
The thermostat is a combination unit shown in the manual in the Atwood a/c installation. Is there a fuse in the thermostat itself?
We switched power plugs this morning and checked more fuses but still no luck. Any and all suggestions welcome.
2017 FR3 30DS
Old 10-25-2017, 07:07 AM   #4
Carl17's Avatar
fuse
The last time we had no power to thermostat the no. 7 fuse 12 volt in panel was blown . Pull fuses out and check or us volt ohm meter. Not a 100 % sure on number but its in the 12 volt box. check them all.
Carl & Bette
2018 Leprechaun
NEW YORK
Carl17 is offline   Reply With Quote
Old 10-25-2017, 07:17 AM   #5
As mentioned, you need to open the thermostat and see if you have any voltage to it, then work backwards from there.
TheWolfPaq82 is online now   Reply With Quote
Old 10-25-2017, 07:27 AM   #6
Ours was a fuse for the air conditioner. The furnace switching is run through it.
Roadhouse is offline   Reply With Quote
Old 10-25-2017, 09:10 AM   #7
ceedog's Avatar
Did you check to see if the thermostat was turned on? There should be a switch on the bottom of the unit.
After that a voltage check would be my next check since you've cycled the breakers & checked the fuses.
Be sure to check every compartment for fuse boxes not mentioned in your coaches literature. In my Berk, there are additional fuse boxes in the coach battery compartment that control a lot of circuits in the back of my coach. They're not mentioned in any literature associated with my coach.
Let us know what you find plz.
It ain't easy being me...I've tried.
ceedog is offline   Reply With Quote
Old 10-26-2017, 04:08 PM   #8
My bet is the fuse at the foot of the bed is tripped ....
antilley is offline   Reply With Quote
Old 10-27-2017, 08:07 PM   #9
Goofy1's Avatar
Thanks for all the suggestions. We made it home and used a portable heater to keep the chill (mostly) off. Our night in Michigan was at ~34 deg F.
I'll start a more indepth evaluation and post back when I get it figured out.
Thanks again!
2017 FR3 30DS
Old 10-30-2017, 12:39 PM   #10
Goofy1's Avatar
Update 2.0
We got home and took the stuff out of the fridge and our clothes in the house. Finally get back to clean and work on the RV. Start up the generator, push the on/off button on the thermostat and it fires right up!!!! Switch over to heat and the furnace runs like brand new.
To review, on a 30DS the shore power plug is used to plug into the generator output.
The only difference is that I was running on the generator not shore power and I didn't have the jacks down. Other than that everything else was the same.
Suggestions or ideas welcome.
2017 FR3 30DS
thermostat
