08-01-2015, 03:35 PM
Help. No running water at bath room sink and toilet
What do I check ? I get water flow at the kitchen sink, shower, and outside shower; however the toilet and bathroom sink has no water flow. Tried with city water connection and pump. Neither provide water at the bathroom sink and toilet. Everything was working fine previously.
08-01-2015, 03:43 PM
Location: Alberta - East of the Rockies, West of the Rest
Highly unlikely but not impossible is a plugged supply hose, more likely is a kink in the line. If this is the 1st time you're using it check for closed valve on main manifold (if you have one) and also check the supply line for the bathroom is plumbed into the system.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
08-01-2015, 03:46 PM
Possibly plug by construction debris in water line. dismantle your aerator on bathroom sink and clean first. Do same for toilet valve......
Fonzie
08-01-2015, 03:50 PM
Georgia Rally Coordinator
X 2 Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
08-01-2015, 04:08 PM
Yup it was the aerator. Just have to find it for the toilet. Great idea thank you
08-02-2015, 04:39 PM
The shower head probably needs cleaning too! Been there when the flow suddenly changes to a dribble
2016 Vibe 268RKS
2015 Chev 2500HD
08-26-2015, 09:03 AM
I just noticed that my FR3 is doing the same thing. Did you find it for the toilet, and if so, where was it?
thanks
2014 FR3 30DS
2005 Dodge Dakota 4WD
08-26-2015, 09:39 AM
thanks
At the foot flush valve.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
08-26-2015, 10:29 AM
I fixed the sink, but looking at the toilet, I haven't a clue where the aerator might be. Can you provide me with specifics as to what you did to get to the aerator at the toilet.
thanks
2014 FR3 30DS
08-26-2015, 10:43 AM
thanks
There is no aerator on the toilet.
You need to remove the flush valve on the foot valve and clean it.
TURBS
2011 32bhok Sabre
08-26-2015, 01:07 PM
Turbs, I appreciate you trying to help me, but simply saying "remove the flush valve" will only provoke a "deer in the headlight" look from me.
I need to know "how" to remove the flush valve (its why I asked for specifics from fdp, since he's done it on the FR3). How and what steps are involved. thanks.
08-26-2015, 02:11 PM
No problem lol
TURBS
2011 32bhok Sabre
08-26-2015, 02:25 PM
Turn off water at outside source. Unscrew the large plastic nut at the bottom of your commode, usually near floor in rear. Has a plastic pipe/hose going into the floor or wall. Clean out anything loose or granular and reconnect. Try it out. Here's mine. I had to do this 2 months ago.
2018 Forester 3011 DS
08-26-2015, 03:10 PM
Hey KSWhoDat,
Here is a pic from my FR3 bottom back of toilet, pointing at toilet valve connection. There is a screen inside that needs to be removed and cleaned
The next two pics are from manual that came with coach
Item 6 b. b.
08-27-2015, 08:05 AM
Thanks guys, really appreciate it. The pics are great!
2014 FR3 30DS
08-27-2015, 10:36 AM
Your very welcome.
08-27-2015, 12:59 PM
Love this forum for the ton of info available.
08-27-2015, 11:49 PM
Been there several times. Most clog due to little bits of plastic from water system construction. After a few clean out haven't had a problem. Fingers crossed...
