Old 08-01-2015, 03:35 PM   #1
fdp
Help. No running water at bath room sink and toilet
What do I check ? I get water flow at the kitchen sink, shower, and outside shower; however the toilet and bathroom sink has no water flow. Tried with city water connection and pump. Neither provide water at the bathroom sink and toilet. Everything was working fine previously.
fdp is offline   Reply With Quote
Old 08-01-2015, 03:43 PM   #2
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Highly unlikely but not impossible is a plugged supply hose, more likely is a kink in the line. If this is the 1st time you're using it check for closed valve on main manifold (if you have one) and also check the supply line for the bathroom is plumbed into the system.
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 08-01-2015, 03:46 PM   #3
fonzie's Avatar
Possibly plug by construction debris in water line. dismantle your aerator on bathroom sink and clean first. Do same for toilet valve......
Fonzie
Old 08-01-2015, 03:50 PM   #4
Georgia Frog Rally 2018
aceinspp's Avatar
X 2 Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 08-01-2015, 04:08 PM   #5
fdp
Yup it was the aerator. Just have to find it for the toilet. Great idea thank you
Old 08-02-2015, 04:39 PM   #6
The shower head probably needs cleaning too! Been there when the flow suddenly changes to a dribble
2016 Vibe 268RKS
2015 Chev 2500HD
Mewcasa is offline   Reply With Quote
Old 08-26-2015, 09:03 AM   #7
KsWhoDat's Avatar
I just noticed that my FR3 is doing the same thing. Did you find it for the toilet, and if so, where was it?
thanks
Jim & Cyndi
2014 FR3 30DS
2005 Dodge Dakota 4WD
KsWhoDat is offline   Reply With Quote
Old 08-26-2015, 09:39 AM   #8
TURBS's Avatar
thanks
At the foot flush valve.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-26-2015, 10:29 AM   #9
KsWhoDat's Avatar
I fixed the sink, but looking at the toilet, I haven't a clue where the aerator might be. Can you provide me with specifics as to what you did to get to the aerator at the toilet.
thanks
Jim & Cyndi
2014 FR3 30DS
Old 08-26-2015, 10:43 AM   #10
TURBS's Avatar
thanks
There is no aerator on the toilet.
You need to remove the flush valve on the foot valve and clean it.
TURBS
2011 32bhok Sabre
roo, water
