Old 07-14-2015, 12:27 PM   #1
Help-removing Jensen DVD/Radio faceplate?
So I'm trying to connect wires to the Jensen in the wall unit; found the square head tool to fit the screws (4) but they seem to just spin and not come out; does this mean there's nuts on the back? Has anyone taken this out and how? Did you have to pop off the deco wood plate that the Bed Switch, TV plug and light switch is mounted on?
Thanks for any help
TravellingBs is offline   Reply With Quote
Old 07-14-2015, 05:20 PM   #2
Technorick's Avatar
First. Be sure you are using the correct size square driver. I bought a set of them just for that stupid radio. Each time I remove it I find I used the size too big at first.
Then as I do for mine, grab the radio frame and slightly pull on each corner as you unscrew one corner at a time. The bite on. The screws are deep. They are wood screws. No nuts. As I have removed mine about five times for different projects stripped the wood on one and placed a wooden toothpick in the hole before reassembly.
2014 FR330 DS
Technorick is offline   Reply With Quote
Old 07-14-2015, 08:35 PM   #3
Thank you Technorick! That's it!
dvd, jensen, radio
