Old 11-23-2015, 06:07 PM   #1
twojump36's Avatar
Hot Water Heater Fire
Last week I went to winterize my FR3 30DS...
When I opened the water heater compartment to remove the diode out of the tank, I noticed black stuff in the compartment bottom. I looked it over and immediately seen a burned wire and melted plastic....
The water heater was working the last time we camped (3 weeks ago) and we haven't used the coach since.
I have a shut down list we go through every time we drive the thing. My wife and I both go over each item and we check off that it has been completed before we move. ie awning rolled up, fridge turned off, hot water off, pump off, steps up, slide-outs in.... you get the picture...
This is what my hot water heater looks like right now. Any ideas of what caused this or why it happened?....
2015 FR3 30 DS
1995 Wrangler
Miles 4600
Days Camped 48
twojump36 is offline   Reply With Quote
Old 11-23-2015, 06:33 PM   #2
wmtire's Avatar
Your Emergency Cut Off (ECO) hi-limit/thermostats are behind that rubber cover. You will have two or these, one for the 120 volt AC electric heating element, and the other for the 12 volt DSI/propane.
It looks like the 12 volt side may have burned behind the rubber cover. Can you remove it to check. It will look similar to this. We want to look at the Eco/thermostats to see if the wiring or other has caught fire.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 11-23-2015, 06:46 PM   #3
Witch Doctor's Avatar
I would agree but you still might have had some roll out if it was on propane, if not then I would say your limit isn't working...
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 11-23-2015, 06:52 PM   #4
2015 FR3
JEGNCJG's Avatar
Are you sure the electric switch was in the off positlon ? Without water pressure it would over heat and shortout.
JEGNCJG is offline   Reply With Quote
Old 11-23-2015, 06:53 PM   #5
wmtire's Avatar
Wait a sec, I can now see what you are referring to with a burned wire. Disregard my previous post. You have a brown wire in the back that goes to your propane valve that has caught fire, and burned the bottom outside portion of the Hi-limit/thermostat cover.
Hold on a sec and let me pull a schematic
Old 11-23-2015, 06:59 PM   #6
wmtire's Avatar
Old 11-23-2015, 06:59 PM   #7
Former Full Timer
Duckogram's Avatar
It does not look like the switch was the problem. Look at the wire below the switch and the plug below that. Both are scorched and the switch cover is curled up from the bottom. It appears that you had a gas flow problem through the tube and the flame came out of the air mixture port. My guess is that you have an eight legged hitch hiker.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 11-23-2015, 07:06 PM   #8
Is there a part missing in the burner tube. It looks like the screen and the adjuster is missing. Look at the damage beginning just above it.
Old 11-23-2015, 07:10 PM   #9
Pickin' & Campin'
I agree. Flame backed up into mixture tube and scorched what you see in the photo.
Either a spider or a HUGE gust of wind.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 11-23-2015, 07:34 PM   #10
Would low propane pressure cause this? I'm not to familiar with propane systems, but thats my guess. It sure looks like the flame came out of the tube, inboard, and caught the cover, wiring, and the CB cover on fire. I know on our 30DS (which this isn't model specific heater really), there is no cover over that intake. Ours looks just like yours.
KansasFR3 is offline   Reply With Quote
heater, hot water, water, water heater
