Old 07-10-2018, 02:10 PM   #1
House Battery water level checking
Recently replaced house batteries before long trip. They are located on passenger side in a compartment. Trying to see into those cells is really difficult. Any of you have a solution besides a mirror held over the exposed cell and a headlamp being reflected into it (it doesn't work well).
sjohnsonmbb is offline   Reply With Quote
Old 07-11-2018, 07:49 AM   #2
SeaDog's Avatar
there are automatic systems like the ProFill that allow you to service the batteries to proper level without having to visually see each cell.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 07-11-2018, 05:31 PM   #3
TY. I'm in the road now. Any suggestions on where to purchase?
Old 07-11-2018, 08:18 PM   #4
SeaDog's Avatar
Here is a link to ProFill https://flow-rite.com/battery-watering/pro-fill They sell the system on Amazon for around $57.00
Retired Navy
Old 07-12-2018, 05:07 PM   #5
Gave up on mirror and flash light Someone suggested an inspection camera- small hand held screen/gun with a 36 inch fiber optic flexible wand. Bought at Harbor Frieght on sale for abt 60 bucks. Placing camera over battery cell and add water and look for the density mixtures of water and acid swirling to cover plate. Not ideal but works better than mirror. Bright sunlight diminishes visibility-got to be creative and adjust. Plus found other uses for it.
twoclaws is offline   Reply With Quote
Old 07-12-2018, 05:18 PM   #6
If you have some room above the batteries then one of these works great. Fill it with distilled water then put spout in cell opening and push down. Water will flow until electrolyte covers vent hole in spout automatically shutting off flow.
Around $12 at Walmart.
Unlike a "Watering System" you can also use it on all your other batteries on cars, trucks, etc. Just hard to use on small lawn/garden and motorcycle batteries as the spout is too large.
These were a staple item in all "Gas Stations" up until Self Service took over.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 07-16-2018, 05:58 AM   #7
bareftn's Avatar
Is your battery water low that often that you need to check so much and so often??
bareftn is offline   Reply With Quote
battery, check, water
