Generally once you remove the lens, usually held in place by notches and stubs that fit it them, by squeezing the lens lightly in the right place, there are a couple screws driven through the base into the ceiling. Back those out and the wiring should be the only thing holding the light in the air.
If you have a meter, through on on there as it's highly unusual for LCD's to burn out. LED's last a long time is one of their benefits. Might be the switch in the fixture or a wire lose either at the fixture or on the supplying connection.
A pic would help be more specific but that should have you headed the right direction unless you have something really different for lighting.
2020 Chevrolet 2500 LTZ, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart.
