Old 09-13-2018, 07:25 PM   #1
How do I drain the fresh water tank
Winterizi g and we'd the drain. The fresh water tank. But how
colourful64 is offline   Reply With Quote
Old 09-13-2018, 08:01 PM   #2
gomatthew's Avatar
There should be a low point drain under the coach that has a screw top
2015 FR3 DS30
Franklin, TN
franklinrvrental.com
gomatthew is offline   Reply With Quote
Old 09-13-2018, 08:01 PM   #3
Novice Travel Trailer Guy
benchmarks's Avatar
Should be a plug underneath.
2018 Flagstaff Micro Lite 25BRDS Travel Trailer
2018 Chevrolet Silverado 2500 LTZ
benchmarks is offline   Reply With Quote
Old 09-13-2018, 08:02 PM   #4
gomatthew's Avatar
Mine is blue pex capped off
2015 FR3 DS30
Franklin, TN
Old 09-13-2018, 08:56 PM   #5
under the rig you will find 2 low point drains. near your tank, you will also find an overflow pipe and a drain pipe for you fw tank. The overflow will not have a valve on it. The drain will have a valve.
Old 09-13-2018, 08:57 PM   #6
Low point drains will not drain the FW tank. they only drain the water lines.
Old 09-14-2018, 01:49 AM   #7
rk06382's Avatar
If you are not sure, I would have someone show you. When winterizing, it is critical to do it right.
The point I am making is: My low point has two pipes with plastic caps & the FW tank overflow and is on the right under the hatch that has the water pump. I can not vouch for where yours low point is. One pipe does drains the FW tank.
I winterized mine at a RV dealer that will de-winterized for free in the spring. Last year he had to replace the water pump because it had a stuck valve. They have awful water so I drained and refilled the FW tank after I got home.
Robert
2018 FR3 28DS | Boondock 99% of the time
Samlex EVO-3012 Inverter/Charger | 600ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | SnapPads | SumoSprings | Koni Shocks | RVLock
Solar Power & Battle Born batteries
rk06382 is offline   Reply With Quote
Old 09-14-2018, 04:56 AM   #8
Locate the water pump, which is often hidden away behind or under something, and you’ll find the FW tank drain. You can also turn the pump on to help find it, with a faucet open, to get the process started.
2006 Viking Velocity 22RS
2018 GMC Canyon Quad w/tow pkg
Nature Coast of Florida and loving it
emoney is offline   Reply With Quote
Old 09-14-2018, 05:19 AM   #9
The low point drains are red and blue. They drain the waterlines only. The freshwater tank has two lines. One overflow and one drain. The drain has a valve and the overflow does not. This is how the majority of RV's work. (just for the NOT MINE crowd)
Old 09-19-2018, 01:03 AM   #10
Thanks guys. Git er done. Not my first t ii me winterizing. Just went brain dead on this one... Husband gets all proud when he comes home and it's all done
drain, fresh water, tank, water, water tank
