05-07-2017, 09:55 PM
How to air in the tires
What's the secret ? Is there an attachment to buy?
05-07-2017, 10:32 PM
Based on your question your best bet would be to take it to a tire shop and have them air your tires
Retired Navy
2016 Flagstaff 26 FKWS
05-07-2017, 10:35 PM
Aaah no... I need to know how to do it myself and can't find an attachment to fit it the tiny hole
05-07-2017, 10:48 PM
I'm not sure I fully understand your question or the "tiny hole" reference. Are you talking about the inside tire on your rear duals, and not being able to get an air chuck to the inside valve stem? If so, yes, they make several chucks that are longer...maybe 6 to 8 inches, on a solid metal stem, that will allow you to reach that inside valve stem.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2021 Chevy Silverado 3500HD DRW 4X4 Duramax
“It's not how old you are, it's how you are old.” ― Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
05-07-2017, 10:51 PM
Mike and Yvonne
05-08-2017, 12:26 AM
We are gonna check it out tomorrow .. the thing is if we pulled into a pump. They already have their own fitting right? On The front tire valve stem is inside the hub cap and if you stick the compressor fitting in there... the angle is wrong and it's impossible to fit! Am I the only one with this problem
05-08-2017, 12:52 AM
Not sure what part of the country you live or travel in but out here the chances or any place but maybe a Truck stop and not always them having a good usable airing station is slim to none. Plan to have what you will need. There are many affordable compressor options but we carry a small tank type compressor and then packed away a small high pressure low flow 12 volt type. The best of those can be like this: https://www.amazon.com/Viair-40047-A...air+compressor OR CHEAPER but lower quality and reliability would be in the range of $59 to $89 at Harbor Freight.
You are right, YOU HAVE TO BE ABLE TO DO it but you will likely need your owe equipment as well.
Tom48
In Sunny So Cal /w
Now in 2005 Holiday Rambler Ambassador DP and The Hot Air Balloon RESTLESS
NO MORE Tricked out
2017 Sandstorm 250 T.H.
05-08-2017, 06:42 AM
I use Viair it works great. You can watch a demo on you tube.
05-08-2017, 09:01 AM
Curiouser and Curiouser
We had the same issue. The valve stem for the inside tires was easily accessible but the outside tire valve stem is in a little cut-out. We found a valve stem extender that was angled so that the stems for the outside tires now also protrude from the cutout.
The extenders for the FR3 were more difficult to find as the FR3 tires are smaller and most of the kits are for the larger tires. Be sure to order one that is for our smaller tires. If you need the part number, I can get it for you when I am back home in a week.
Finch
2016 FR3 30DS
05-08-2017, 09:57 AM
Just as confused as you
Just a question about these class A's. Don't they have air ride or air brakes? If they do then you should have an air compressor and storage tank on board.
Richard & Jill
05-08-2017, 10:10 AM
Sounds like you need valve stem extenders.
Checking and airing up your tires is a basic (but important) part of R/V traveling.
Hopefully you can get what you need to do it.
05-08-2017, 10:26 AM
First things first. I assume you have had the valve stems replaced with the longer solid stems (not just extensions). This makes it a lot easier to air up and more stable if you intend to put on tire pressure monitors on the end. I recommend these. This is what I have on my rig. DL1FC Chrome Duallyvalve Kit https://tiretraker.com/products.php?cat=3
Second, I have found and recommend the https://www.amazon.com/Viair-40047-A.../dp/B004B68XGC so you can air anywhere and anytime. It is a complete kit. These items have worked for me over the years and in my opinion are gold!
Safe travels
2016.5 FR3 30DS AKA "Serenity"
Searching for that perfect spot with loving Wife & 2 mini dachshunds
05-08-2017, 11:04 AM
We have a gas mh . We don't have an on board compressor... so the issue is when we bring it to a pump the fittings on the pump are permanently attached so these fittings won't fit . I'm wondering what's going on? Surely we are not the only ones that have this problem .
05-08-2017, 11:05 AM
No they do not have air brakes or onboard compressor
05-08-2017, 12:14 PM
You gotta take the wheel simulators off, or bend them like i did.
Or just put extensions on.
05-08-2017, 12:16 PM
HOLY **** ARE THOSE EXPENSIVE! You can get a crossfires for less and they're better for your tire wear and easier to fill.
https://www.amazon.com/Crossfire-Dua.../dp/B00030410M
05-08-2017, 12:23 PM
Did you read the suggestions about valve stem extensions?
05-08-2017, 12:37 PM
I would stop by a tire store and let them look at your problem first hand. Bet they can recommend a solution, best for your rig !
Butch Wilson
2016'Flagstaff T21QBHW A-Frame
05-08-2017, 01:08 PM
You are not the only one with this problem...
I would go to a tire store and have them add valve stem extentons so you are able to add air in the future. Not all class A's have the same wheels so dealing with someone in person is your best bet.
Daryl
2014 Georgetown 351ds
05-08-2017, 07:27 PM
Colourful's grammatical flow is poetic.
I could (try to) read his posts all night long.....[emoji108]
