Old 03-19-2017, 12:11 PM   #1
how to take off ac duct vent in 30ds
ok, so i should understand how to do this, but i can't..... The duct vents are screwed into the ceiling so it appears the only way to take it off for cleaning, viewing obstruction in the duct is to figure how how to take the swivel part off/the inside part with rorates 360. any ideas, my finger is pointed to the seam in which i believe i need to manipulate.Click image for larger version
Combatcoal is offline   Reply With Quote
Old 03-19-2017, 12:34 PM   #2
leisurelarry's Avatar
Originally Posted by Combatcoal View Post
ok, so i should understand how to do this, but i can't..... The duct vents are screwed into the ceiling so it appears the only way to take it off for cleaning, viewing obstruction in the duct is to figure how how to take the swivel part off/the inside part with rorates 360. any ideas, my finger is pointed to the seam in which i believe i need to manipulate.Attachment 132184
They will unsnap from the base with moderate gentle prying with a flat tip screwdriver. If I remember correctly there are 3 maybe 4 catches.
leisurelarry is offline   Reply With Quote
Old 03-19-2017, 12:48 PM   #3
thx larry, not the outer part as that apppears screwed in, but rather the rotating part. you saying put the flathead and pry where my finger is at ( the seam), or rather go into the louvers on two opposite ends and manipulate the clips that appear to be "hanging" on the shelf which allows it to rotate ( try to pry those off the ledge)?
Old 03-19-2017, 12:53 PM   #4
Flybob's Avatar
The rotating portion has a center pin that snaps into a hole in the flange. Carefully pull or pry it off putting even outward pressure on the center of the director. Once it is off, you can simply remove the screws that secure the flange to the wall/ceiling. It simply snaps back in when done.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-19-2017, 02:50 PM   #5
Sounds like flybob has a different setup than me. There are 3 tabs on each side, 6 total. You can see them if you look through the vent. I had removed mine to spray foam and and block off the duct area ahead of the forward and aft vents. It's a dead area and it increased my cooling capacity very much.
Old 03-19-2017, 03:10 PM   #6
yea i see those 3 tabs on ea end. almost like you need a hook to pry them off the ledge they ride on. a flat head screwdriver doesnt seem the easiest methos if at all
Old 03-19-2017, 03:14 PM   #7
Your absolutely correct! It takes a bit of persuasion!
Old 03-19-2017, 03:15 PM   #8
Originally Posted by combatcoal View Post
yea i see those 3 tabs on ea end. Almost like you need a hook to pry them off the ledge they ride on. A flat head screwdriver doesnt seem the easiest methos if at all
ID:	132207Click image for larger version
Old 03-19-2017, 03:39 PM   #9
Old 03-19-2017, 03:40 PM   #10
you da man Larry!!
vent
