Old 04-01-2018, 05:58 PM   #1
I would like to cut a hole in the floor
We would like to install a table between the captain seats of our 2015 30 ds ... it entails a keyhole cut through the floor.. do anyone know what the floors maw of or how deep we can cut without hitting vitals
colourful64 is offline   Reply With Quote
Old 04-01-2018, 06:11 PM   #2
FrankG's Avatar
You can get surface mount and flush mount devices for the round table legs. The surface mount only requires 3/4" screws. The flush mount will require a 2 1/4" hole saw about 2" deep, this may be problematic if you don't know what is underneath. Hope this helps.
2018 Haulin 6 x 12 Cargo Trailer by Forest River (A legal Tow )
2017 Laredo 325RL
2016 Vengeance 29V Sold
2016 Ram 2500, 4x4 Laramie CCSB 6.7 Cummins
FrankG is offline   Reply With Quote
Old 04-01-2018, 07:13 PM   #3
Yes Frank I know All that. My question is... what is under there?
Old 04-01-2018, 10:50 PM   #4
The floors are 1.625” thick. 1/2” of OSB on top. 1/8” or 3/16” Luan on bottom with foam in between.
alexchuang is offline   Reply With Quote
Old 04-02-2018, 01:06 AM   #5
Ok perfect thank you!
Old 04-02-2018, 12:11 PM   #6
rlh1957's Avatar
My wife skipped No and went right to Hell No you're not! Looks like I have to prove someone else did it first, successfully!
rlh1957 is offline   Reply With Quote
Old 04-02-2018, 09:30 PM   #7
Telstar's Avatar
Know where your tanks are before drilling past the thickness of the floor. You could start with a 1/8” hole making sure not to go past clearing the floor then use 12g electric wire to probe. If it goes past the distance you need then bend it to make sure nothing is within the diameter needed.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2018 Ram Laramie 3500 6'4" box 2WD
Demco AutoSlide 18k
Telstar is offline   Reply With Quote
Old 04-03-2018, 10:41 AM   #8
TLAK's Avatar
Colorful, could you just open the dog house and look? Perhaps with a mirror. Or is it blocked?
2015 FR3 30DS
Towing 2016 Chevy Sonic LT
TLAK is offline   Reply With Quote
Old 04-03-2018, 10:55 AM   #9
Wolverine 1945's Avatar
I am with your DW !!!
LOL !!!
Wolverine 1945 is offline   Reply With Quote
Old 04-03-2018, 06:18 PM   #10
And I am the wife! And I will be cutting the dam thing.. why bother to tell her if you are sure it’s clear
floor
