Old 09-20-2015, 01:39 PM   #1
Branchman
Installation of slideout motor
Hi all,
I just got my FR back from having the main slide motor replaced.
It took five weeks for the dealer to get the part and 6 hours to install.
My extended warranty covered 2.5 hours of labor and $100 less on the part than te dealer charged.
Oy!
I just went to put the bedroom slide out and guess what?
That's right, it is broken showing the same symptoms !
My question is........how difficult is it to replace the motor, assuming I can get one.
I am quite handy and willing to tackle the project!
We are heading South in 3 weeks.
Thanks in advance
Branchman is offline   Reply With Quote
Old 09-20-2015, 02:39 PM   #2
HAPPY WHEN RV'ING
drivmsafe's Avatar
Did it work when you picked it up from the dealer? What are the symptoms? Could be the problem is something other than the motor. Maybe a bad switch or a short in the line.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 09-20-2015, 03:37 PM   #3
Branchman
The main slide made the same noise before the motor and gearbox were replaced.
Now the bedroom slide is making the same noise. it moves in or out
Several inches before stopping and making a grinding noise.
I am guessing that since te symptoms are te same that the motor/gearbox need to be replaced
Old 09-20-2015, 04:03 PM   #4
PhoneDude 8289's Avatar
There is allot to read about the plastic gear inside the gearbox. It's been awhile but there was somebody on this forum that ordered a bunch of those gears and was selling them. Do a search here and on E-Bay
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 09-21-2015, 02:42 PM   #5
Contact forest river directly. This was a known quality issue, they should help you with repair cost.
MandK is offline   Reply With Quote
Old 09-21-2015, 03:46 PM   #6
Norco Accuslide
I have had 2 motors replaced and contacted Norco Customer Service, a Norco technician returned my call and helped me with cables on the slide after one came loose. You can find the contact info online or call.
CUSTOMER SERVICE
Polly Ferrando
800-347-2232
conddave is offline   Reply With Quote
Old 09-21-2015, 03:48 PM   #7
You can also download installation,maintenance and service pdf's from their website.
Old 09-30-2015, 12:02 PM   #8
niedobry1's Avatar
Our dealer in Elkhart got the motor gearbox in 1 hour and replaced the broken part in less than four hours. All covered in warranty less than one year
niedobry1 is offline   Reply With Quote
Old 09-30-2015, 11:03 PM   #9
I carry a spare motor with the gear box. You can buy them off ebay from a guy in california. Takes a little work to get to the motor (and put the trim back) The actual motor replacement is pretty easy. Since having replaced one and now having a spare....there are of course nomore failures......its like they know.
zippyzrx is offline   Reply With Quote
Old 12-09-2015, 10:25 PM   #10
My main slide broke. FR3 30DS 2913 model.
The repair guy in Tucson tells me FR is charging $250 for motor and gear assembly. Should be down here in 1 to 2 weeks.
When he removed the covers showing the gears, chain, cables. Noted one side was tighter then the other. Also cables, top and bottom had slack between them. Suggests to me, either cables stretched / slipped or might have been Mis-adjusted?
Will know more after it gets fixed!
Ron Chamber is offline   Reply With Quote
Old 12-10-2015, 12:59 PM   #11
Branchman, I'm curious, who do you have your extended warranty with?
2014 FR3 30DS
2005 Dodge Dakota 4WD
RiverRat22 is offline   Reply With Quote
Old 12-11-2015, 11:50 PM   #12
StephanFR3's Avatar
Make a report to NHTSA, might get a recall going if they get enough reports.
StephanFR3 is offline   Reply With Quote
Old 12-12-2015, 02:49 PM   #13
Certified Curmudgeon
I dont think this is a safety issue. So unless the slide extends while motoring down the road, NHTSA is not going to be interested.
A flood of complaints to the BBB with a copy to RIVA might get better results.
Mike Dropped
Old 12-12-2015, 10:44 PM   #14
niedobry1's Avatar
Bedroom slide.... Less than one week for the gearbox, did not need new motor and three hours to replace my my mobile RV repair guy.
Old 12-12-2015, 11:03 PM   #15
StephanFR3's Avatar
There is already a recall for same system but different part and different year but the recall came from complaint to NHTSA.
Old 12-12-2015, 11:08 PM   #16
StephanFR3's Avatar
If your gear is broken there is nothing holding the slide in any more. That is why you should make blocks of wood that fit above inside of closed slide when the gear or cable is broken. So it can't fall out while driving.
Old 12-12-2015, 11:10 PM   #17
StephanFR3's Avatar
BBB has zero enforcement power.
Old 12-13-2015, 12:49 PM   #18
That is true however if there is no official recall it MIGHT generate enough attention to get factory support at an acceptable level. BTW, RIVA has no enforcement power either.
So IF the slide can come out while the unit is in motion then NHTSA paper would be appropriate. Dèjá Vu
Mike Dropped
Old 12-13-2015, 01:00 PM   #19
StephanFR3's Avatar
Pardon my ignorance, but what is RIVA? It didn't come up on Google did you mean RVIA? Never mind found it it was RVIA.
Old 12-13-2015, 08:42 PM   #20
Yep. I pfat pfingered it and schpell czech didnt help a bit.
Sorry about that.
Mike Dropped
slide, slide out
