09-20-2015, 01:39 PM
Branchman
Installation of slideout motor
Hi all,
I just got my FR back from having the main slide motor replaced.
It took five weeks for the dealer to get the part and 6 hours to install.
My extended warranty covered 2.5 hours of labor and $100 less on the part than te dealer charged.
Oy!
I just went to put the bedroom slide out and guess what?
That's right, it is broken showing the same symptoms !
My question is........how difficult is it to replace the motor, assuming I can get one.
I am quite handy and willing to tackle the project!
We are heading South in 3 weeks.
Thanks in advance
09-20-2015, 02:39 PM
HAPPY WHEN RV'ING
Did it work when you picked it up from the dealer? What are the symptoms? Could be the problem is something other than the motor. Maybe a bad switch or a short in the line.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
09-20-2015, 03:37 PM
Branchman
The main slide made the same noise before the motor and gearbox were replaced.
Now the bedroom slide is making the same noise. it moves in or out
Several inches before stopping and making a grinding noise.
I am guessing that since te symptoms are te same that the motor/gearbox need to be replaced
09-20-2015, 04:03 PM
There is allot to read about the plastic gear inside the gearbox. It's been awhile but there was somebody on this forum that ordered a bunch of those gears and was selling them. Do a search here and on E-Bay
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
09-21-2015, 02:42 PM
Contact forest river directly. This was a known quality issue, they should help you with repair cost.
09-21-2015, 03:46 PM
Norco Accuslide
I have had 2 motors replaced and contacted Norco Customer Service, a Norco technician returned my call and helped me with cables on the slide after one came loose. You can find the contact info online or call.
CUSTOMER SERVICE
Polly Ferrando
800-347-2232
09-21-2015, 03:48 PM
You can also download installation,maintenance and service pdf's from their website.
09-30-2015, 12:02 PM
Our dealer in Elkhart got the motor gearbox in 1 hour and replaced the broken part in less than four hours. All covered in warranty less than one year
09-30-2015, 11:03 PM
I carry a spare motor with the gear box. You can buy them off ebay from a guy in california. Takes a little work to get to the motor (and put the trim back) The actual motor replacement is pretty easy. Since having replaced one and now having a spare....there are of course nomore failures......its like they know.
12-09-2015, 10:25 PM
My main slide broke. FR3 30DS 2913 model.
The repair guy in Tucson tells me FR is charging $250 for motor and gear assembly. Should be down here in 1 to 2 weeks.
When he removed the covers showing the gears, chain, cables. Noted one side was tighter then the other. Also cables, top and bottom had slack between them. Suggests to me, either cables stretched / slipped or might have been Mis-adjusted?
Will know more after it gets fixed!
12-10-2015, 12:59 PM
Branchman, I'm curious, who do you have your extended warranty with?
2014 FR3 30DS
2005 Dodge Dakota 4WD
12-11-2015, 11:50 PM
Make a report to NHTSA, might get a recall going if they get enough reports.
12-12-2015, 02:49 PM
Certified Curmudgeon
I dont think this is a safety issue. So unless the slide extends while motoring down the road, NHTSA is not going to be interested.
A flood of complaints to the BBB with a copy to RIVA might get better results.
Mike Dropped
12-12-2015, 10:44 PM
Bedroom slide.... Less than one week for the gearbox, did not need new motor and three hours to replace my my mobile RV repair guy.
12-12-2015, 11:03 PM
There is already a recall for same system but different part and different year but the recall came from complaint to NHTSA.
12-12-2015, 11:08 PM
If your gear is broken there is nothing holding the slide in any more. That is why you should make blocks of wood that fit above inside of closed slide when the gear or cable is broken. So it can't fall out while driving.
12-12-2015, 11:10 PM
BBB has zero enforcement power.
12-13-2015, 12:49 PM
That is true however if there is no official recall it MIGHT generate enough attention to get factory support at an acceptable level. BTW, RIVA has no enforcement power either.
So IF the slide can come out while the unit is in motion then NHTSA paper would be appropriate. Dèjá Vu
Mike Dropped
12-13-2015, 01:00 PM
Pardon my ignorance, but what is RIVA? It didn't come up on Google did you mean RVIA? Never mind found it it was RVIA.
12-13-2015, 08:42 PM
Yep. I pfat pfingered it and schpell czech didnt help a bit.
Sorry about that.
Mike Dropped
