Old 07-03-2018, 10:11 AM   #1
Installing Lithium Batteries under sofa
I am thinking about installing 2 lithium batteries under the sofa in our 2015 FR3 28DS instead of installing them underneath in the battery compartment so they donít get stolen. Any drawbacks to doing this?
Jon
2015 FR3 28DS
JonnyVinSB is offline   Reply With Quote
Old 07-03-2018, 10:36 AM   #2
Fulltime family RVer
No drawbacks. Just extra work of running new wires.
ependydad is online now   Reply With Quote
Old 07-03-2018, 01:34 PM   #3
Broken Toe
Cowracer's Avatar
IIRC, Lithium batts can be prone to fires if improperly charged. Make sure you have a compatible charging system designed for lithium batts.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016
Rockwood Signature Ultralite 8329ss
"Snowball" 2017 Ram 2500 Laramie Diesel
ProPride 3P Hitch - "Yeah. It's worth it."
Cowracer is online now   Reply With Quote
Old 07-03-2018, 01:44 PM   #4
rk06382's Avatar
Tim
No true. LiFePO4 with a BMS are safer than a lead acid.
Robert
2018 FR3 28DS
Samlex EVO-3012 Inverter/Charger| 400ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | Dometic 320 | SnapPads |
Solar Power & Battle Born batteries thread
rk06382 is offline   Reply With Quote
Old 07-03-2018, 03:53 PM   #5
Broken Toe
Cowracer's Avatar
Yeah. What I said.
Tim
"Camper" 2016
Old 07-03-2018, 04:17 PM   #6
rk06382's Avatar
Jon
2015 FR3 28DS
If you install them under sofa, you will need to put them in a battery box or rack with a cover as they have bare terminals. Also as posted above you will need to route your battery cable to your load. Also you will need lithium battery chargers. I programed my Solar Charge controller & Inverter/Charger for LiFePO4 lithium. I had to remove the stock Converter/Charger.
I have mine in the battery bay. I am going to enclose my battery bay because my Battle Born LiFePO4 batteries do not charge below 32F. I also wanted to keep dust out. I think my batteries should be safe as I changed out all 13 basement locks. Also my FR3 28DS is stored in my driveway all winter.
All the 12v cables for the FR3 are in the battery bay. If you keep the lead-acid batteries, then were will have two different battery systems to maintain.
I went with one system to keep it simpler and maximize storage in the FR3. My Inverter/Charger can recharge my batteries at 100 amps.
See my post: Expanding compartment space for 2200 Watt Inverter/Charger
Robert
2018 FR3 28DS
Old 07-04-2018, 12:35 PM   #7
None that I know of. There's no water involved and no fumes so no ventilation necessary I placed my lithium in the battery compartment with a key lock and my motorhome is at home which is safe. I did close off the ventilation to the compartment to keep the area free of unnecessary road dirt. You'll love the lithium upgrade.
Dpelaez is offline   Reply With Quote
Old 07-04-2018, 12:38 PM   #8
Just waiting for them to sell at a price I can love as well.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 07-04-2018, 01:18 PM   #9
Cowracer,
Lithium probe to fires were the lithium mercury batteries. Lithium is now LIFO and they come with a built in BMS. No more fires .
Old 07-04-2018, 04:13 PM   #10
camaraderie's Avatar
There's prolly less danger from LifePo4's than regular batts...but the real danger is to your wallet...since you need charging systems that are quite different than existing converters...and there are a number of cheap "lithium compatible" chargers that aren't gonna take care of them properly. At around a grand a piece...you can put a serious dent in the wallet if you treat them the same as wet cells. A built in BMS in the battery alone is not the solution...despite what some salespeople will say.
On an amp hours delivered over a lifetime basis...lithiums are the cheapest batteries per amp hour that exist...but you need to treat them exactly right or they can quickly become the most expensive per amp hour.
________
Cam
2015 Georgetown 280DS
camaraderie is offline   Reply With Quote
batteries
