Old 07-24-2019, 07:51 PM   #1
Crossfire8207's Avatar
Interior and exterior led lights.
I wanted to ask if I will need to re solder the lose wire on the attached pictures or just buy new housing to replace light?
ID:	210734   Click image for larger version
ID:	210735   Click image for larger version
Nickersons
2016 Forest River 30DS
Sumo springs
Crossfire8207 is offline   Reply With Quote
Old 07-24-2019, 10:07 PM   #2
leisurelarry's Avatar
I just replaced the entire fixture when the diodes started burning out. The bottom picture is the exact original fixture in my 2015 30DS. I had 11 of them. Iíve been replacing them with these. 5 Pack RV LED Ceiling Double Dome... https://www.amazon.com/dp/B0733RQDXL...p_mob_ap_share
leisurelarry is offline   Reply With Quote
Old 07-25-2019, 04:01 AM   #3
rk06382's Avatar
I replaced my original ceiling lights with two-mode lights. I bought the two mode LED lamps from Amazon:
AutoEC LED Dome Light, 2 Color Mode 12V LED RV Ceiling Dome Light Fixture, Interior Replacement Light for RV, Trailer, Camper, Motorhome, Boat
2 Mode Fashionable Design --- The Dome Light with on-off-on switch, can change the color from pure white to warm white, give you different feel. Warm white light output provides a cozy illuminated environment just like home. I have six installed & control the color mode with a wall switch. It only draws 5 Watts and provides total 1000 lumens of brightness.
My FR3 in White Light.
My FR3 in Warm Light
I have six installed & plan to replace more.
Robert
2018 FR3 28DS
Samlex EVO-3012 Inverter/Charger| 400ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | Dometic 320 | SnapPads |
Solar Power & Battle Born batteries thread
rk06382 is offline   Reply With Quote
Old 07-25-2019, 04:24 AM   #4
Awesome thank you very much for a great solution to our light situation you guys are very helpful on this forum for all us newbies really appreciate this. Happy rving!!!
Nickersons
Sumo springs
Old 07-27-2019, 07:23 PM   #5
Papaduck's Avatar
I also replaced all of my original ceiling light on our 2016 30DS with the same LEDs for the same reason, they started losing diodes on a number of them. I also went a step further and added window tinting material to certain fixtures (i.e. over the living room seating area and the fixture over the head of the bed area). I just went by the local window tinting business and asked for some scrap material in various tint levels and cut a piece to lay into the lenses assembly. Give it a try, it works very well.
Chuck & Donna
U.S. Army - Retired
2016 FR3 30DS w/2016 Chevy Colorado Toad
Days Camped: 2017 - 45, 2018 - 52, 2019 - 28
Papaduck is offline   Reply With Quote
Old 07-27-2019, 08:22 PM   #6
Great idea! Iíve got some scraps from doing my windows. Iíll try that, especially over the head of the king bed.
Old 07-27-2019, 08:24 PM   #7
Did you remove a panel to expose that area above your refer?
Old 07-27-2019, 10:58 PM   #8
rk06382's Avatar
No, It came that way.
Robert
2018 FR3 28DS
Old 07-28-2019, 12:07 PM   #9
Papaduck's Avatar
Use Wago connectors when you replace the light assembly. Easy Peezee!!
Chuck & Donna
U.S. Army - Retired
Old 07-28-2019, 01:08 PM   #10
Thank you papaduck
Nickersons
Sumo springs
exterior, led, light
