Old 04-29-2015, 10:17 PM   #1
Jacks issues
So... Is it normal for the tires ti come off the ground? And why are webhaving a problem with leveling.. We use thw auto leveler and we are all scowwidget
colourful64 is online now   Reply With Quote
Old 04-30-2015, 07:57 AM   #2
The CHF could be affecting the jacks, not sure, I have not used my jacks since doing the fix. I will be buying the hellwig adjustable links just in case.
Weldon
WGFR3 is offline   Reply With Quote
Old 04-30-2015, 08:48 AM   #3
Why would the CHF change anything with the jacks/levelers?
I've done the CHF and have had no problems. Prior to the CHF, the diode in the levelers went out, which sent the jacks all the way down and they got stuck there. Had to manually retract them and get the diode replaced.
The levelers aren't calibrated to a specific setting, that I know of, so doing the CHF would have no bearing on the jacks. My assumption is that the levelers only read what is needed to level the coach from it's current position.
If the CHF changes the geometry of the levelers then adding boards or blocks under the tires (or jacks for that matter) prior to engaging the levelers would also change the geometry and would cause problems. I've experience neither.
I say that they are unrelated. Excessive slope would cause the jacks to fully go down and lift the tires off the ground or you have a diode problem.
Meathouse is offline   Reply With Quote
Old 04-30-2015, 09:28 AM   #4
Not saying that it is a problem, just throwing it out there. I only mentioned it because when I was doing my research I read where someone else had a problem with their jacks after doing their CHF, it could be and probably is non related. Moving the links could shorten the movement of the suspension causing it to be pulled up with the jacks but I have only heard of a couple of people with that situation so it could be an unrelated issue.
Weldon
Old 04-30-2015, 10:12 AM   #5
dan-nickie's Avatar
Why did this turn into a CHF discussion?
The OP didn't mention it.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 04-30-2015, 10:22 AM   #6
I just mentioned it because of this discussion:
Cheap Handling Fix
post #29 from ttincali
"I did both front and rear right before a 1800 mile trip last month because I was beginning to think I was a fool for not doing it - since everyone says this a no brainer. I had no issues prior to doing it and to be honest really didn't notice much of a difference after. But now my leveling jacks are a problem - I hit auto at the first campground since doing it and my rear tires lifted off the ground! Thinking now this was a big mistake and am going to revert back"
I thought nothing of it when I read this because this was the only person I read that had the problem and so thought it was unrelated and still might be?
Just sharing my thought on a possible...but not definite reason for his jack issues because I believe colorful64 just recently made the CHF changes.
Weldon
Old 04-30-2015, 10:30 AM   #7
bubbles's Avatar
I would just level the coach in MANUAL MODE. Your AUTO level probably needs to be recalibrated per the manual. Tires coming off the ground (not all 4) is not a big deal and will happen occasionally.
Old 04-30-2015, 11:15 AM   #8
HAPPY WHEN RV'ING
drivmsafe's Avatar
I've heard that tires coming off the ground is not a good thing. They say that if this happens, run what ever tires come up onto blocks to compensate and then retract jacks.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 04-30-2015, 11:32 AM   #9
R&J Silverback's Avatar
2x with bubbles not to hard to do a calibration, then you know.
Ron & Jan and black dog(Bella)
2011 Ram 3500 crew cab 4x4, 6sp manual,342's 8ft.bed
2014 CC Silverback 29ik
R&J Silverback is offline   Reply With Quote
Old 04-30-2015, 08:12 PM   #10
Technorick's Avatar
The leveling system in this model scares me. As I am afraid I'll over extend a jack. I don't use auto mode because it lifts all four tires off the ground. I use manual and blocks of wood. I did not know you could recalibrate the system. Did not get a leveling system manual. What's he sequence to recalibrate?
2014 FR330 DS
Technorick is offline   Reply With Quote
jacks
