Old 09-10-2014, 11:42 AM   #1
Jacks up or down during storage
Thinking about winter storage. It gets cold in northern Ohio. Should I store with Jack up or down? Should I store with slides in or out?
Albert1950 is offline   Reply With Quote
Old 09-10-2014, 12:00 PM   #2
Slides in, jacks down. Reason is, if a tire goes flat, plus helps reduce weight on wheels during storage, and keeps it stable in winds.
Uncle Buck is offline   Reply With Quote
Old 09-10-2014, 12:07 PM   #3
heavynlori's Avatar
X2 - same for us !!!
heavynlori is offline   Reply With Quote
Old 09-10-2014, 12:13 PM   #4
ARLO
Jacks out, slide in.
rlocicero is offline   Reply With Quote
Old 09-10-2014, 12:16 PM   #5
Thanks everyone for the quick reply's. Should I protect jacks somehow?
Old 09-10-2014, 12:42 PM   #6
Anacortesians
It really depends what climatic conditions prevail at your storage site. The first winter with our Georgetown, I put the jacks down so as to relieve some of the load on the tires. Within two weeks, I notice a film of rust starting to show on the piston rods. I polished it off quickly.
I contacted the manufacturer for advice. They said "If you're close to salt water, don't leave them down without a protective wrap on them". I queried back on their definition of "close". I was gob-smacked when they said "less than 50 miles". We're probably 100 feet from a saltwater marina - the houses across the street have private docks!
What I've done since is to lower the jacks on one side to get both the wheels on that side off the ground, then I rotate the wheels 90 degrees then retract the jacks. Two weeks later, I do the same on the other side. Repeat the procedure four times on each side during the off-season. If we do take the rig out, I drop the next couple of procedures.
I don't know for sure if it helps the tires, but I don't get the flat-spot bumping of the tires for the first 5 miles or so first time out in the spring and the jacks are in fine shape.
Frank and Eileen
No longer RVers or FR owners
Old 09-10-2014, 12:46 PM   #7
I would store them up for protection from the weather and also no Chance of anything hitting them. if you store them down then I would cover the chrome rods with grease to protect them a little messy but cheaper than new cylinders.
lbrunning is offline   Reply With Quote
Old 09-10-2014, 01:17 PM   #8
Old car's Avatar
I keep my jacks up. Anything touching the ground is a rodent path to the interior.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 09-10-2014, 01:23 PM   #9
If in a storage lot, I would put the slides in and jacks up. If at home and NOT near salt water, I would leave the slides out and the jacks down and cycle the slides and jacks occasionally. We do on our 5er even tho' we have reg. stab jacks.
Old 09-10-2014, 10:07 PM   #10
Bobb36's Avatar
Aren't you putting unnecessary pressure on the hydraulic system all winter???
2014 FR3 30DS
2014 JEEP WRANGLER WILLYS
Bobb36 is offline   Reply With Quote
Old 09-10-2014, 11:17 PM   #11
The system is designed to handle the pressure.
zippyzrx is offline   Reply With Quote
Old 09-21-2014, 08:58 AM   #12
I used the levelers to lift the FR3 enough to place cement blocks under the frame then retracted them. This took the pressure off the tires during the winter as well. We covered with an Adco cover and also ran the engine at least twice a month during the winter here in Maine
TravellingBs is offline   Reply With Quote
storage, jacks
